BIKELAND > FORUMS > ZX-14.com > Thread: sprocket specialist anodized or no? NEW TOPIC NEW POLL POST REPLY
fast-14
posted April 20, 2009 02:58 PM
i was going to pick up a 40t rear when i was given a choice between a reg and a hard anodized. the lady said the hard anodize is good for twice the miles. so is there truth to that or just hype?
what do most of y'all run with?
'08 sapphire blue zx 14
still have a learners permit..
14nooby
posted April 20, 2009 03:27 PM
Vortex
zixxer14
Damn that was Quick
posted April 20, 2009 04:18 PM
Steel is real! Sunstar steel will get you 2 to 3 times as far as alum.
posted April 20, 2009 05:01 PM
VORTEX.
FasterThanStink
posted April 20, 2009 06:48 PM
Anodize. If it is bare aluminum it will wear very quickly.
That's what gets you.
Flame On
Fuel Air & Spark
posted April 20, 2009 07:25 PM
I think they make aluminum sprockets now with steal teeth . I would not risk a full aluminum sprocket on a 14
77 RD 400
80 GS1000 GT
06 ZX14
LAB3
posted April 20, 2009 07:41 PM
+1 or DrivenRacing.com case hardened C45 steel zinc plated, drilled for weight reduction balanced and tested for trueness.
ZX14Mike
posted April 20, 2009 09:32 PM
I've used the Sprocket Specialist hard anodized on my ZX 14 from 3 weeks after i got it and its still going strong...........its expensive but well worth the money Sprocket Specialist custom makes the hard anodized monthly in any gearing you want and it also looks great in black.
MJ
posted April 21, 2009 01:57 AM
Steel
Superman T
posted April 21, 2009 06:10 AM
Vortex
LAB3
posted April 21, 2009 06:25 AM
Vortex
I have one a 42 and after 2000 Hard miles you can see wear at the bottom of the teeth.
Now that the stock chain has stretched out I have a steel 43.
The soft material just will Not hold up for Hard use compaired to steel.
Vortex is fine if you just ride on the hiway and do not do wheelies or
drag race. They will take abuse............... just not as long as steel.
posted April 21, 2009 07:34 AM
Steel is great if you don't mind a 1 lb. heavier sprocket. A good aluminum can last thousands of miles, if you care for it properly.
Aluminum will easily hold the power of the 14...as for the finish, hard anodized is better than bare, for certain.
fast-14
posted April 21, 2009 05:43 PM
thanks for the replies, guys. lot of different opinions.
i'm going to give the anodized a try and see how it holds up. i always have the stock sprocket to throw back on.
0.2648549079895 seconds processing time
