BIKELAND > FORUMS > ZX-14.com > Thread: HELP!!! NEW TOPIC NEW POLL POST REPLY
06redzx14
posted April 15, 2009 07:03 PM
HELP!!!
changed the oil pan and i have a leak. the leak isn't too bad, but the oil light came on when I was on the way home. soon as I saw the light I turned the bike off and walked it down the road. has anyone else has anyone had this happen after changing pans?
posted April 15, 2009 07:05 PM
Did the oil light come on because it leaked out that much ?
Wheelie
Old Man
posted April 15, 2009 07:08 PM        Edited By: Wheelie on 16 Apr 2009 03:08
Lucky14 had a small leak, not sure how he corrected it, or where it was
wee
posted April 15, 2009 07:09 PM
wee
Doesn't sound like a small leak if it leaked enough to put on the oil light ..!
posted April 15, 2009 07:12 PM
I have put 4 or 5 pans on zx14s and even reused the gasket a few times and no leaks .. I can't see how this would happen ..
06redzx14
posted April 15, 2009 07:13 PM
it was dark when I put it up so I didn't get a chance to check the level. didn't really look like enough to cause it to go low
zxbob
posted April 15, 2009 07:15 PM
Is the wire to your oil presure sending unit tight ?
Bob
Lucky14
posted April 15, 2009 07:20 PM
wee
I put a Clem's pan on and had a verrrrrrry small leak, just a few drops a day. It was so little that it was somewhat hard to isolate. Turned out to be the drain plug and some teflon tape on the threads cured the leak.
06redzx14
should be but I'll retighten it with the socket
06redzx14
posted April 16, 2009 03:46 PM
think I got it. small leak at the drain plug and the level sensor broke. when I removed the rubber boot oil came out.
0.24720788002014 seconds processing time
