BIKELAND > FORUMS > ZX-14.com > Thread: lift point? NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted April 15, 2009 01:52 PM
lift point?
I need to take the weight off the forks, can i set the oil pan on some blocks?
14nooby
posted April 15, 2009 02:04 PM
I did that and it work well. Just make sure the bike is balanced when you jack it up. I used a scissor jack and wood.
posted April 15, 2009 02:07 PM        Edited By: Shane661 on 15 Apr 2009 22:08
If you are going to do that, make sure that the block of wood extends equal to or past the very edges of the engine case...otherwise you can damage the pan AND drop the bike over. And obviously you will need to balance the bike..sketchy, imo.
I jacked the rear of the bike up in this way in order to swap my swingarm. I'd really suggest a front pin stand for what you are talking about.
3000psi and falling
posted April 15, 2009 02:21 PM
Ok thanks guys.
14nooby
posted April 15, 2009 03:38 PM
But hell, why be safe?
posted April 15, 2009 03:46 PM
Because your talking about a $10000 plus bike
3000psi and falling
posted April 15, 2009 04:16 PM
I straped the back of the bike to the floor, took 10min and worked great, You could run full speed into the side of it and it would not fall over..lol
0.41156983375549 seconds processing time
