BIKELAND > FORUMS > ZX-14.com > Thread: FYI regarding Center Stands and Slip-ons NEW TOPIC NEW POLL POST REPLY
John F
posted April 11, 2009 05:41 PM        Edited By: John F on 12 Apr 2009 01:53
Over the past couple of weeks I've been researching slip-on systems for my '08, and my biggest concern was that I want to retain my center stand. I checked with a number of vendors and found that almost no one has the center stand stop bracket welded on the right side mid-pipe for the '08. Area P was very helpful and even emailed me a picture of a peg guys are welding on the center stand as a stop against the swing arm, but I wasn't sure about that route. I emailed Ti-Force because I like their systems, and I found that they only offer a high mount system for the '08 (a shame, because it raises the passenger foot pegs), but they do offer a center stand stop bracket for $45. I bought one and it mounts to the frame under the little bracket that holds the peg for the center stand return spring. Problem solved! Since I couldn't see going with the high mount system I decided to buy a Yosh R-77, which is really great. The leg on the left side of the center stand with the foot peg had to be bent a little to clear the pipe though (nothing a torch and a length of pipe couldn't handle!). Anyway, I just wanted to pass this on as an option.
John
John F
posted April 11, 2009 05:52 PM
Oh, and for those of you looking for pipes for your bike, Area P was the only vendor who really went out of his way write a very helpful response. I'm a little partial to Yoshimura exhaust (fond memories of my '91 ZX-11), so I went that route, but it was obvious Area P cares for the sport and for their customers. You might keep that in mind...
posted April 11, 2009 06:50 PM
informative!
and Area P
ratbyk
posted April 11, 2009 08:04 PM
When I put a center stand on my 06 with a Muzzy 4-1 there was no stop. Looked at it for a couple of minutes. Light bulb went on in head! Took a stainless steel rad hose clamp. Placed around the middle pipe just before muffler. Positioned with the screw part of clamp facing to the inside. Sat perfect as a bumper stop. That was 22,000kms ago. Still there, no probs. $1.25 clamp, stainless is almost invisible on the stainless pipe. Grin Grin!
WindSwordNinja
posted April 12, 2009 07:39 AM
John do you have a part number for that?
Did you order it directly from Ti-Force?
I had a center stand on mine but took it off when I installed the 4-2-1 exhaust.
I always liked the convenience of it for checking the tires or lubing the chain.
Thanks for the info.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
John F
posted April 12, 2009 01:55 PM
I ordered it over the phone from the U.S. Distributor:
TiForce U.S.A
2515 6th Ave South Birmingham, AL 35233
Tel : 1-205-583-8601
Fax : 1-205-583-8605
Email : tech@tiforce.com
I don't have a part number handy but will look for the packing slip. If I find it I will post it. When I called them the guy I talked to knew what I was referring to.
Mean14
posted May 01, 2009 09:19 AM
Hey Ratbyke, Do you have a pic. I am waiting on the spring to install and I like your clamp idea! PM is not working. Thanks
0.21441197395325 seconds processing time
