BIKELAND > FORUMS > ZX-14.com > Thread: steering damper NEW TOPIC NEW POLL POST REPLY
Newbusa
posted April 06, 2009 10:11 PM
steering damper
Anybody know which steering damper will work with Helibars? I have the Hyperpro but it does not work so well.
Bawls
re-learning to ride
posted April 07, 2009 04:49 AM
gpr or scotts would be my guess... but they're not very strap friendly.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted April 07, 2009 04:57 AM
If he's using helibars, I doubt he's worried ab a strap. I've seen a bunch of gpr's on the 14's and they like them.
MasterBlaster
posted April 07, 2009 07:37 AM
Heres mine I adapted by using a couple of spacers and longer bolts.
Sticks_n_Stones
posted April 07, 2009 07:55 AM
Nice setup masterblaster. Exactly what I was looking for. And yes Eklipse, I plan on running a strap on my 14 that has helibars.
Speaking of which, who makes the best quality affordable strap setup? I already got the brocks lowering setup on the back. Hitting the track soon and gotta try and get my 330lb ass into the 9's to keep up with Gilberjj. Come to think of it, maybe I dont since Gilberjj is selling his bike. lol
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Bawls
re-learning to ride
posted April 07, 2009 08:44 AM
i'm running a schnitz right now and have had nothing but good luck out of it.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Smurfslayer
posted April 07, 2009 09:16 AM
I found the bolts, nuts & washers on amazon.com. The install was a piece of cake.
Dave
www.usrkba.org
  Ignore this member    Click here to visit Smurfslayer's homepage.
Newbusa
posted April 07, 2009 04:40 PM
Yes i do dragrace my zx14,But the Hyperpro is not strap friendly either. Masterblaster, where did you get the bracket that is on the left side bar? That is what i need to get the proper clearance.
MasterBlaster
posted April 08, 2009 05:54 AM
Thats the one that came with the Hyper Pro, its been awhile, but I believe I modified it by shortening the legs, and may have drilled the top of the Helibar mount hole a little larger so the legs of the bracket would seat where the mount bolt head normally sets. When I got my Hyper Pro it was the first version with the defective mounts, and they sent me the improved mount. I fiddled with the spacers untill it all was in alignment, and it worked out fine. Didnt measure anything, but you can see about what you need. Be sure to use high tensile strength bolts. I had everything i needed in my junk box.I didnt want the center pivot to be too high requiring a longer bolt, so put a spacer between the ram rod end and the bar bracket to offset it a little. Luck with it, not too bad of a job to do.
gilberjj
Friend of Fast
posted April 08, 2009 07:46 AM
You're only weapon left is hopes and prayors Sticks! haha I don't think I'll end up selling it. My mind is a mess right now, but I should be getting an Alien head soon so we can do that Brocks vs Muzzys competition.
Sticks_n_Stones
posted April 08, 2009 09:02 AM
Bring it on. Hey, just wanted to apologize for not resending the map to you. Totally forgot! Still need it? Or did you get the first one I sent?
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
gilberjj
Friend of Fast
posted April 08, 2009 09:10 AM
Never got it, but I'm fine now. I have one, thanks though.
0.24047112464905 seconds processing time
