BIKELAND > FORUMS > ZX-14.com > Thread: Need Tech help NEW TOPIC NEW POLL POST REPLY
jarhead
posted April 06, 2009 03:03 PM
Need Tech help
Here goes, over the winter I took the bike down. Every nut bolt and grommet, powder coated everything, and put it back together. Fired the bike for the first time and everything was good except I have no headlights. I have power at the fuse box but not at the plug. It is just the high and lows, the third small light works. Any ideas would be appreciated.
posted April 06, 2009 03:08 PM
relay or fuse blown?
Check the plug that comes out of the handle bar ... I had a problem with mine not being plugged in tight... Also double check your grounds..
jarhead
posted April 06, 2009 03:24 PM
Hoping for either of those, it was dark and the bike was loaded in the trailer for Ryan to map it today so I could not get too deep into it. Ryan should have it done in a day or two and I can start the digging process. I told Ryan to help himself if he gets bored so maybe he will hunt it down for me. Thanks for the info guys, I guess as long as I get it figured out within the next few weeks I am still in good shape. I am in northern Indiana and we had snow on the ground this morning.
Ozonkiller
posted April 07, 2009 08:38 PM
I'm pretty sure that there are 2 fuses. One for the headlights and one for the headlight relay
jdrill04
posted April 07, 2009 08:44 PM
Getting her ready for the busas jarhead
Compton
posted April 07, 2009 09:21 PM
any pics? what color did you powder coat it>
b.w.
MasterBlaster
posted April 08, 2009 05:21 AM
You might check the plugs, sometimes the pins in the plugs can slip back if they are not seated correctly in the plug, and loose contact.
Sticks_n_Stones
posted April 08, 2009 05:54 AM
Could the powdercoating have affected the ground path back to the battery? Find the headlight harness grounding point and run a jumper back to the battery. slim chance but still worth a shot if all else fails. Good Luck
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
jarhead
posted April 08, 2009 03:55 PM
Thanks for all the info guys, I had the everything powdered in gloss black and went to the Candy Lime Green for the plastics, as soon as it gets back from Ryan I will post up some pics. Definately getting ready to beat up on some Busa's that is during daylight hours only for right now.
0.27961802482605 seconds processing time
