BIKELAND > FORUMS > ZX-14.com > Thread: oil drain might drag NEW TOPIC NEW POLL POST REPLY
dabeffect
posted April 03, 2009 09:25 PM
can anyone tell me how to keep my oil pan from draggin the ground and destroyin my motor? iv been told to get a new oil pan, or to move it, i just need to know the best way to fix the problem.
D Brown
posted April 03, 2009 10:48 PM
move the plug to the side of the pan. gives you an extra in of clearance
TooHype
Go Hard or Go Home !!
posted April 04, 2009 12:56 AM
+1
Moved my plug to the rear of the pan and havent had a problem since I did.
00Busa
Trying to go FASTER !
posted April 04, 2009 03:07 AM
Clem's Kawasaki has "modified oil pans" in stock.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
Lucky14
posted April 04, 2009 06:18 AM
+1 .......... and .......... "the price is right."
posted April 04, 2009 06:24 AM
cheapest solution is don't lower it in the first place, but you didn't list your application
posted April 04, 2009 09:03 AM
Keep a eye out in the classifieds for a modified pan. There has beeen quite a few in there the past month or so
0.31309604644775 seconds processing time
