BIKELAND > FORUMS > ZX-14.com > Thread: Problem with GenMar Risers NEW TOPIC NEW POLL POST REPLY
extrapilot
2008 ZX14
posted April 02, 2009 02:43 AM
I have the GenMar K115 risers but they pull very tight on the front brake line when installed.
Will they fit better if I use after market brake lines like Spieglers?
Also, how do they route the Spiegler lines?
MY 2008
TIA
'pilot
'pilot
NeverKnow
posted April 02, 2009 06:38 PM
R U sure they are mounted correctly. I have no issue with mine.
extrapilot
2008 ZX14
posted April 03, 2009 02:07 AM
Yes.......In looking at other sites there have been people with the same issue using stock brake lines. It will stretch the rubber lines about 1/2 in. I'm not comfortable with using it with a stretched line.
Also, the throttle cables hit the front fairing on full left hand turn.
Are you using yours with stock brake lines?
'pilot
'pilot
Bawls
re-learning to ride
posted April 03, 2009 05:07 AM
i had double stacked helibars on my bike and although the res would hit, it wasn't a big deal. my bike is lowered an inch in the trees though so that could explain why my lines weren't stretched tight.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
extrapilot
2008 ZX14
posted April 03, 2009 06:06 AM        Edited By: extrapilot on 3 Apr 2009 14:07
Lowering the front end would definitely help with the short brake line.
I sport tour with my bike so lowering would not be a good option for me.
That's why I was asking about using after market lines, maybe being a little longer that could possible help with using the risers that I have.
'pilot
'pilot
ratbyk
posted April 03, 2009 06:45 AM
Good Harley shops usually stock an assortment of braided stainless. Measure up what length you need and the angle of the banjo end housing. They can likely supply from stock and at a reasonable $.
Also if you live in an area with much industry in it there is likely a hydraulic supply shop around. That is where I had my braided stainless lines made to measure while I waited, Price was very good as well.
gumbybob
posted April 03, 2009 08:31 AM
I got Genmars and the res on the right "just" touches at full left turn on the bars, but not bad.
The brake line is tight but acceptable.
Perhaps it's just tolerances on different bike that make stuff like this fit just a little bit different for each bike.
extrapilot
2008 ZX14
posted April 03, 2009 08:47 AM
Maybe they position the forks just a hair higher on mine, making the line just to tight.
Thanks for the replys guys.
'pilot
'pilot
NeverKnow
posted April 03, 2009 02:53 PM
'pilot
Yes, stock brake lines.
0.21506690979004 seconds processing time
