BIKELAND > FORUMS > ZX-14.com > Thread: 10,000 miles and warped rotors? NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted March 30, 2009 03:26 PM
Ok, For the last couple thousand miles I have felt some pulsating from the front end under hard breaking from 60+ mph. Well it seems to be getting much worse now. And from 100+ mph hard breaking its beyond anything normal.. Anyone had this happen? I sure that the pulsating is from the front breaks. Im under warranty, if its the rotors will they be covered?
pazx14rider
posted March 30, 2009 03:30 PM
I had pulsation at 6000 miles but turned out be just be my front tire was cupped.
posted March 30, 2009 03:37 PM
I doubt your rotor would be covered under warranty, but its always worth a shot! My front end had a little shake in it when my front tire got 6,000 miles on it and got cupped.
gilberjj
Friend of Fast
posted March 30, 2009 04:01 PM
I know somebody who got all new brakes under warranty. Give it a shot!
3000psi and falling
posted March 30, 2009 04:45 PM
Well its a new tire, no cupping or funny wearing at all. And it did the same thing with the old tire. Im sure that its a warped rotor or maybe the floating bolt things are getting crusty and seizing up??
1adam12
posted March 30, 2009 04:56 PM
I had the same thing happen on my 12. Went with galfer rotors and pads fixed the prob.Big bikes are hell on brakes when rode hard in tight curves.
gilberjj
Friend of Fast
posted March 30, 2009 05:09 PM
I ride the piss out of mine in the corners..... Maybe I don't brake hard enough or it's an isolated problem.
FastestBusaAround
I eat Fish...
posted March 30, 2009 06:07 PM
I had 'em on a few of my Kawi's @ lower mileage than that...
FYYFF!!!
posted March 30, 2009 07:44 PM
I BEAT the hell out of my front ZX14 rotors stopping fast in the mountains, tail of the dragon, Cheraholla Skyway, N. Ga, etc etc and I noticed two things:
***they consistently stopped faster than one would EVER expect a huge bike to stop with little brake fade due to extreme heat
***they lasted over 14000 miles of that hell, longer than my litre bike rotors ever do (then the bike and I parted ways or they'd have lasted longer)
Old Guy
posted March 30, 2009 10:39 PM
!9,000 miles, about 10 track days (1200 miles roughly) and I'm just changing pads. Cant believe the brakes work as good as they do!!!!!
try taking a green scrubber and brake cleaner and scrub the rotors. blow out the floating "bolts too.
My warpage cleaned up by doing that. Brake material deposits from heating rotors at track. They are still bluish from that abuse.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
faz
posted March 30, 2009 11:40 PM
From Motorcyclist magazine, March 2009, long term testing of Kawi Concours, with regards to the warped rotors, Dexter Ford writes:
"As for the warped brakes, I took a page from legendary race car crew chief Carrol Smith who says there is no such a thing. What he believes happens is the brake pad material gets transferred unevenly into the disks if the brakes are clamped on when hot and stopped, creating a thick spot. He suggested sanding the disks with old fashioned garnet sandpaper, which worked. Total cost: $1 and 10 minutes of hard labor."
I for one will definitely be trying the above before accusing the disks of being warped.
LAB3
posted March 31, 2009 02:04 AM
Try a little semichrome metal polish on that rotor and clean again and see if most of the
blue goes away. It takes some time and rubbing but you will be suprised. I rubbed a Lot
on Shanes used M14 head pipes and ALL the Blue was gone before I installed them.
It was cold out and I was bored, I know they will turn blue again.. :-)
TooHype
Go Hard or Go Home !!
posted March 31, 2009 02:41 AM
Do you think that semichrome metal polish will get the discoloration of my Alien head muffler? It turned a little brown near the bottom where it connects to the mid pipe.
TooHype
posted March 31, 2009 02:42 AM
I have over 13,00 miles on mine and still havent changed yet.. But it won't be long now.
LAB3
posted March 31, 2009 03:11 AM
Yes, email me labartay@charter.net and I will send you pic's of M14 after several
hours of hard hand rubbing. Then look on page 19 of Shanes build post and look at the
head pipes before a Lot of rubbing. It will take off all brown tarnish, I use a old white sock and a lot of rubbing. But the mid pipe and muffler will look new again easy. Blue on head pipes was a LOT of work with pipes in living room and a 6 pack ... :-)
Louis
Bawls
re-learning to ride
posted March 31, 2009 05:07 AM
try brasso... it got the bronze off of the smeg that i bought from smokin (the one that was on jessejames bike when it bucked him off). it also works great for cleaning the billet end cap.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
dattaway2
Ninja's rule
posted March 31, 2009 09:44 AM
I found the problem with my rotors are tiny pits from corrosion. After riding in the rain, water sets between the pads and rotor and electrolysis creates hundreds of tiny pits. It takes some hard riding to overcome that damage.
INTIMIDA2OR
RED rider!
posted March 31, 2009 09:49 AM
I'm gonna have to go with steve on this one
'06 Passion Red ZX-14
*Lee*
Old Guy
posted March 31, 2009 10:11 AM
My ego likes the blue :lol
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Converted
posted April 02, 2009 02:01 AM
Took a leaf out of Carrol's book and sanded both discs (even thought bike shop stated RHS only was warped). Only tested at low speed around the 'hood but noticed an improvement. Will have another go at 'em with slightly coarser sandpaper.
I am impressed at the cost saving and ease of solution............thanks Faz and Carrol for the tip!
slates
posted April 02, 2009 05:58 AM
dumb questions - What is garnet sandpaper? Buy it at hardware store? What grit do you plan on using?
My rear rotor is "warped" and the tire grabs in one spot when I try to spin it on the rear stand.
Converted
posted April 02, 2009 12:36 PM
Slates - Garnet sandpaper is for use on wood products. I wondered why I would use a wood only sandpaper on a metal disc but, ey, it ain't going to hurt it too much if it is the wrong type.
I used 120 and 180 grit and plenty of elbow grease.
NeverKnow
posted April 02, 2009 06:37 PM
Had same problem with mine at 6500. Kawi is replacing rotors under warranty but not pads. Been a long winter so have not been able to schedule repair as of yet but recently changed pads to buy some time. Changed with ebc sintered brake pads because the bike became unsafe due to the condition you describe. Better at the moment but not by any means where it needs to be. This is a safety issue that Kawi needs to accept accountability for. I would suggest you request replacement rotors.
NeverKnow
posted April 02, 2009 07:44 PM
Garnet will not fills the pores of the disk.
Converted
posted April 03, 2009 01:39 AM
Never know.................did wonder why Garnet was the 'flavour'. Bought some 'wet and dry' when I bought the Garnet just in case....didn't need to use it but still might try.
Gave the bike a decent run today and had to use front anchors at 120kph and use'em firm.......worked great.
Can't claim on Kawa...........bike is outta warranty
0.34208798408508 seconds processing time
