BIKELAND > FORUMS > ZX-14.com > Thread: connecting hub NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted March 28, 2009 04:18 AM
connecting hub
Im connecting the speed input harness for the hub . The directions say where to put the
brown wire but say nothing about the grey wire!!! Any clues? If you help me on this one I will mow your lawn if you pay for my transport to get there!!
Doug Mackay Australia
Silver08
posted March 28, 2009 06:20 AM
Brown is speed input, Grey is gear position input, IF the 14 has a rotory type sensor you use the grey, if not you dont. (i dont know)
this is from PC site:
If your bike has a rotary gear position sensor then
you will need to determine which wire from the sensor
is the signal (refer to the service manual, NOTE section of
this guide or www.powercommander.com). Most
Kawasakis and Suzukis use a rotary type sensor.
2 Crimp the supplied wire tap to this wire.
3 Connect the GREY wire from the Gear Position Hub harness to the wire tap. If your bike does NOT have a rotary type
sensor then the GREY wire will not be used.
4 To setup the Gear Position Input go to POWER COMMANDER TOOLS - HUB CONFIGURATION - GEAR SETUP. Click
on the drop menu at the top, center of the screen. Choose Gear Position if you are connected to a rotary type sensor.
5 Put the bike in first gear and click on the “Auto” box for first gear. Repeat this step for each gear. This is best performed
on a dyno but can also be done with the bike on a rear stand. The Green slider bar should be at different ranges of the
scale for each gear. If the slider bar does not move then you may not have a good connection at the rotary switch/speed
sensor. Click OK when done.
6 If you are using the speed input for calculating gear position then choose Speed calc from the drop down menu. Repeat
step 5. Make sure you have calibrated your speed input before performing this step.
7 After the gear position has been calibrated the main screen of the software will show current gear position. If the HUB is
connected to the Dynojet LCD display gear position will also be shown.
08 ZX14
Silver08
posted March 28, 2009 06:21 AM
look like the speed input will work without using the GREY wire. it is for gear position
08 ZX14
Douglas Home
posted March 28, 2009 10:27 AM
Thanks silver , its 4AM here and Im sucking coffee about to get into another day of bike mods . Excited , yes , better than drugs , yes , Im now addicted to perfecting my launch and this forum!!!
Silver08
posted March 28, 2009 10:58 AM
i know all too well what you mean
08 ZX14
Douglas Home
posted March 28, 2009 11:06 AM
The past can never catch up when your on a 14!!!
0.23141598701477 seconds processing time
