BIKELAND > FORUMS > ZX-14.com > Thread: Tag Light Bulb NEW TOPIC NEW POLL POST REPLY
TooHype
Go Hard or Go Home !!
posted March 27, 2009 10:04 PM
Tag Light Bulb
I installed a Muzzy fender eliminator which uses the stock tag light and since I have done so I have had to replace several bulbs for some unknown reason. Does anyone have any idea why this may be happening. Do I need to add some type of grease to the bottom of the bulb or tighten something or what ?
kawasakijockey
posted March 28, 2009 03:55 AM
It could be vibration maybe?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted March 28, 2009 06:48 AM
go led
NeverKnow
posted March 28, 2009 07:32 AM
Sounds to me light a bad ground... excessive currenct to the filement. Check the ground wire for a poor conncection.
posted March 28, 2009 09:04 AM
go led
+1
Tater
Shakin off the Haters
posted March 28, 2009 09:24 AM
i dont run a tag light the taillight lites up the tag
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
00Busa
Trying to go FASTER !
posted March 28, 2009 10:13 AM
It's the ground for sure (has the same problem). Check underneath the seat and look at the connection-you can moce it around and actually make the light flicker... I put another type connection there and never had another problem with it.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
Bawls
re-learning to ride
posted March 28, 2009 10:18 AM
mine has a hole drilled in the undertail just below the tail light that works great... ghetto? of course... does it work? like a fucking charm lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
TooHype
posted March 28, 2009 05:57 PM
That will be the 1st thing I check. Thanx
TooHype
posted March 28, 2009 05:59 PM
That makes perfect since Thanx for the feed back.
0.2545280456543 seconds processing time
