BIKELAND > FORUMS > ZX-14.com > Thread: 16/43 or 17/40 NEW TOPIC NEW POLL POST REPLY
eb2318
zx14
posted March 27, 2009 04:52 AM
16/43 or 17/40
im about 200 suited
i luv my zx14
00Busa
Trying to go FASTER !
posted March 27, 2009 05:11 AM
17/40 is taller than stock, if you trying to drag race that's not going to work for you. 16/43 is going to be tough if you are still stock wheel base. There's no easy combo, unfortunately , you just have to figure out exactly what you want to do with the bike.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
posted March 27, 2009 05:12 AM
Uhh...those two gearing choices are about 5.5 teeth apart....
eb2318
zx14
posted March 27, 2009 05:18 AM
Im not at stock wheelbase im at 65' right now but im going to shorten the bike up too 62' because im spinning bad have shinko too.
i luv my zx14
kaw-rick
posted March 27, 2009 05:22 AM
16-43 or lower. But i would start there.
00Busa
Is the Shinko the U-soft ? I think the 16/43 would be the closer choice for you. Before you shorten the bike check your tire and shock settings to get the best out of the 65". I've seen bikes longer than that hook with U-softs !
'00 Busa / '06 14 /
Red1
posted March 27, 2009 05:40 AM
Brock ran his best 1/4 mile times with 17/40 gearing, He said this helped keep the wheelies down in first gear on stock wheelbase. I just changed my stock wheelbase to 16/40 and as soon as the weather permits I'm going to see how that works with SWB.
Red12/Blue14
00Busa
posted March 27, 2009 05:56 AM
I ran 6.00s with 16/40 gearing when I was SWB, but couldn't get into the fives. Brock's bike is FLYING and he has "jockeys" running those low times that you see. Ricky is running that combo on his Brock sponsored/tuned SS14 but its probably real close to 200hp !
'00 Busa / '06 14 /
Silver08
posted March 27, 2009 06:50 AM
I'm 65in with 16-44. I have run the same numbers with 16-43 though. If you really want to eliminate traction problems, get a shinko 008 slick. they are cheap. I have to run 10-12psi in a U soft or power race to hook, but i run 24-27psi in the 008 shinko and hook if that tells you anything.
the longer wheelbase will be easier to ride once you get it working right.
08 ZX14
Bawls
re-learning to ride
posted March 27, 2009 12:14 PM
smokin just did some testing on the 17/40 combo on his stock wheelbase bike. Said that it worked much better than 17/41. I would say that if you're not having wheely problems you should run the lower gearing. What gearing are you running now?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
kaw-rick
posted March 27, 2009 12:43 PM
A lighter guy can get away with tall gearing. Heavy guys need the gear. I get faster everytime i gear lower. Especially considering hes extended. Also saves clutches.
Wheelie
Old Man
posted March 27, 2009 12:51 PM
a bigger guy will toast more clutches with that gearing.
wee
posted March 27, 2009 03:14 PM
I run 16/43 at 69" and a shinkio 003 (not ultrasoft) and I have no problem with spinning... 1.42 60ft. Imo I wouldn't shorten the bike bc of wheelspin when it isn't that long now. I'd get the suspension/tire right. Like said above, MUCH easier to ride at longer wheelbase!
ZX14Mike
posted March 27, 2009 04:55 PM
Look usually gearing isnt a cut and dry answer..............BUT if your talking a 200 pound rider at 65 inches theres no F&%$n way you should be using 17/40 gearing............the only reason Smokin and Gadsen are running that gearing is because they are STOCK WB and fairly light riders.
kaw-rick
posted March 27, 2009 05:46 PM
truth
eb2318
zx14
posted March 27, 2009 05:47 PM
thank for the imput I wont be using 17/40s. what about clutch mods ive read those brock spacers help alot with gettin out the gate anybody with any feedback on them?
i luv my zx14
Silver08
posted March 27, 2009 07:50 PM
I have brock springs and spacers, dont really think they help with leaving. definately firmer clutch feel. I am about to go to stock springs and CL lockup for more feel and see what happens
08 ZX14
blackbullet76
posted March 27, 2009 10:18 PM
I run 16/41 on the street. At the track I run 16/44. I have tried the track combo on the street while stretched and lowered, it's alot of fun!
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
0.28427505493164 seconds processing time
