BIKELAND > FORUMS > ZX-14.com > Thread: HPC 2nd Fan NEW TOPIC NEW POLL POST REPLY
Sigma14
posted March 11, 2009 02:20 PM
HPC 2nd Fan
Has anyone installed the HPC $50 fan on there 14 yet?
LAB3
posted March 11, 2009 02:35 PM
Not yet, mine is on the bench. Looking at a manual switches, PMR etc. maybe wire straight to battery and inline fuse.
HPC instructions has you splice into factory fan and a different factory fuse. Not saying that is bad, just looking a all the options.
Smurfslayer
posted March 12, 2009 10:50 AM
not exactly...
...but maybe this will help -
http://www.bikeland.org/board/viewthread.php?FID=27&TID=32272&pagenumber=3
The 10" car fan moves ( I think ) about 210% of the stock fan, give or take and draws about as much current. I did have to space the radiator out about 3/8" on the bottom, but besides this it was a part for part swap. I would prefer it came on a little earlier, maybe 10 degrees or so, but it does work.
HTH
Dave
www.usrkba.org
  Ignore this member    Click here to visit Smurfslayer's homepage.
LAB3
posted March 12, 2009 11:27 AM
Thanks Dave I will look at the link. When I install the Muzzy M14 I purchased from Shane I will install the brace that came with the exhaust that moves the left side of the radiator out some. It looks like if I move the radiator out much more it will hit the fairing opening?? But I will make a brace to move the bottom too. The HPC($50.00) is a 7 inch or so and about 2.5 inches thick. I know it is weird of me but I hate to cut into the factory wires. The PMR switch will also let me have 12V for a GPS or Radar Detector with the second switch. And just wire straight to battery with inline fuse for second fan and GPS. Old Guy had a good idea too and explained where he slpiced into his wires. I am going to look at Monster Cables 12V harness or ???
Smurfslayer
posted March 12, 2009 11:46 AM
well...
I'm sure your 14 will love the 10" much better than the 7"...
Just sayin'
FAN that is...
Here's another link that may be instructive
http://www.jcna.com/library/tech/tech0008.html
Dave
www.usrkba.org
LAB3
posted March 12, 2009 04:00 PM
Just sayin'
FAN that is...
Cool, I will check it out.... The link that is,,, If I had 10" I'd still be Single.... :-)
Kingo
posted March 13, 2009 03:37 AM
I just installed the HPC fan on my 07. You have to tear half of the bike apart and nearly remove the radiator. I wired into the existing fan and replaced the fuse like it said to. I took it out for a spin and the meter only reached one bar over half way. This was on about a 75 degree day. You can really feel the hot air being pulled through both those fans now. I think its going to make a huge diff.
Kingo
0.24452805519104 seconds processing time
