BIKELAND > FORUMS > ZX-14.com > Thread: Rear wheel adjusters NEW TOPIC NEW POLL POST REPLY
Newf14
2007 ZX1400
posted March 02, 2009 05:21 AM
I was wondering when u guys adjust the rear wheel do you follow the marks on the swing arm?? I really dont think that the marks are the same on both sides of the swingarm, I usually measure the same distance on either side with a tape measure.
Newf14
FIFTH
The Magnificent Bastard
posted March 02, 2009 05:47 AM
I went by the marks with the stock length. Since I have added the extensions, I noticed the marks are off by as much as a whole mark. I now measure each side and then place a metal ruler next to my chain to make sure it is straight as well.
kawasakijockey
posted March 02, 2009 06:04 AM
The truest way is to measure center to center on both sides from the swingarm pivot to axle.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Old Guy
posted March 02, 2009 09:12 AM
On ANY bike.
Just so happens my marks are nuts on??!!
Still measure with a shot of twine that doesn't stretch.
Knotted at one end at mid of axle/swingarm nut and thumb nail holding center of other.
Walk around bike and check other side.
our swingarms are too rounded to check side clearance from leading edge of rim.
That is a good way of making sure tire is aligned.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
blackbullet76
posted March 02, 2009 12:05 PM
Just curious, what is the effect if the rear wheel isn't exactly straight?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
ninjaboy311
posted March 02, 2009 01:20 PM
Uneven chain and sprocket wear...
Bike will pull in a direction other than 'straight'...
Unsafe!!
ratbyk
posted March 02, 2009 01:22 PM
__________________________________________________
Bike will "dog track". Meaning both wheels will still be rolling straight ahead but will not be in line with each other. The more misalignment on the chain adjusters the more dog track that takes place.
Bluebyyou
Gettin My Curve On
posted March 02, 2009 03:57 PM
If you use a good rigid straight edge along the length of the chain or have a good eye you can detect unequal adjustment. In other words you'll see a sway or hump along it's length. Improperly adjusted, the chain will eat on your sprockets and vise versa.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
3000psi and falling
posted March 02, 2009 07:55 PM
My 08 marks were right on. I Made a alignment tool out of 2 jackstands and some fishing line to verify them. Here is one way to check. http://www.motorcyclistonline.com/howto/string_align_motorcycle_wheels/index.html
Bawls
re-learning to ride
posted March 02, 2009 08:52 PM
assist
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
0.44941902160645 seconds processing time
