BIKELAND > FORUMS > ZX-14.com > Thread: 1/8th mile results for 1/25/2009 NEW TOPIC NEW POLL POST REPLY
Bawls
re-learning to ride
posted January 24, 2009 05:47 PM
Well... I didn't reach my goal of a 6.399999 but i was consistently in the low 6.4's and consistantly running high 1.5 60fts today. Air kind of sucked which is why my MPH is a little low. I really need to get my 60fts down some more, but it is what it is lol.
Set up is still as follows,,,
Lowering bones on middle hole, front lowered an inch and strapped, flies removed, 16t front sprocket, shinko 003 soft @ 18PSI, and 87 pump gas.
My best times of the day were launching at 4500 rpm. I suspect that the low rpm launches weren't working today due to the stickier track and bad air.
RT--------.180
60ft-------1.581
330ft-----4.231
mph-----87.407
1/8th-----6.410
mph-----113.531
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
rACeRs
posted January 24, 2009 06:35 PM
Looking good! Have you tried to run more air in the tire? Im sure that tire is eating up some mph especially with that pressure. And if you used the lowest hole on the bones that would also help some.
Good job
9.1 @ 149 w/ 1.57 60' SWB
Bawls
re-learning to ride
posted January 24, 2009 06:42 PM
It's my daily driver and i ride it to the track so i'm keeping it on the middle hole. Also, with the 16t front sprocket I have traction problems. The track was pretty cold today which is why I was below 20. I usually run 20-25 psi and if that doesn't work then I start dropping down until i hook.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
pazx14rider
posted January 25, 2009 06:07 AM
Bawls or Racer... are you guys adjusting your rear shock at all (stiffining it up)?
0.21960306167603 seconds processing time
