BIKELAND > FORUMS > ZX-14.com > Thread: swingarm adjustment NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted January 22, 2009 04:02 PM
swingarm adjustment
ok well finally had some decent weather to get out and ride on the roaring toys extensions spinning like crazy, i knew i was too long came back home and took chain apart and was gonna shoten it as much as the extensions would allow but the damn brake hanger isnt slotted long enough to go forward as much as i want. anyone else experience this or know what im even talking about.....i need to go about 2 inches further in. right now the black axle block is even with the 4th line from the back of extension.....right now the Center of the axle is 4 3/4 inches from the TIP of the stock arm.....
07 LE bolt on bike
icarus
posted January 22, 2009 04:11 PM        Edited By: icarus on 23 Jan 2009 00:13
Try rotating the brake bracket 180 degrees. The one that is bolted to the extension.
8.820 @ 161.05
kawboy81
Busa Eater
posted January 22, 2009 04:28 PM
u can rotate it, i thought of that....but the brake hanger dont allow for that much movement forward. its not slotted long enough to slide further forward.
07 LE bolt on bike
Juice McGoose
posted January 22, 2009 05:09 PM
Well, sounds like you need to slot it more. Can you post some pictures?
kawboy81
Busa Eater
posted January 22, 2009 07:49 PM
im on a cell phone..... i can text u some pictures! lol
07 LE bolt on bike
ninjaboy311
posted January 23, 2009 05:52 AM
Can you measure your current brake hanger, just the barrel of it. I have one that came with my swingarm from McIntosh that was too short (they sent me the wrong one). If it will work for you, I'll send it for a few bucks to cover shipping.
I am at work right now so I can't measure the one I have.
Send me an email to my house to remind me....
pchabaud@cox.net
pazx14rider
posted January 23, 2009 03:04 PM
Kaw let me know how you make out i still have mine to install you might beable to possibly save me some time and bitching!
kawboy81
Busa Eater
posted January 23, 2009 08:21 PM
pazx - well unless im doing something totally wrong..... the roaring toys is 2-8 inches of adjustment but due to the stock brake hanger bracket it makes the first 4 inches basically un-usable. so its like i have to sit it out longer than what i wanted... i wanted about 4 inches over from stock location which would put the axle basically towards the beginning of the extension, but the furthest i could go in was the 4th line from the back of the extension. i was wanting the back tire even or maybe a inch past tail. i dont know...im sure all the extensions are made the same.... how r u guys getting 62" and less???????
07 LE bolt on bike
zx14kawboi
just wanna be fast
posted January 24, 2009 06:03 PM
i had the same problem .all you have to do is grind some of the tab on the extension off .not much trouble just aggravating
kawboy81
Busa Eater
posted January 25, 2009 06:02 AM
thats all i needed to know.......will do that. thanks alot
07 LE bolt on bike
pazx14rider
posted January 25, 2009 06:08 AM
hey post up some pics when u get all done if u can!
01smokes
posted January 25, 2009 09:19 AM
+1 i had to do the same thing
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
0.22079992294312 seconds processing time
