BIKELAND > FORUMS > ZX-14.com > Thread: Small LED Lighting?? NEW TOPIC NEW POLL POST REPLY
posted December 25, 2008 11:56 AM
Does anyone know of a small, light, LED lighting unit that I could use in place of a single headlight? I'm looking for something small and very light, with enough output to help when I have drive the bike up into the trailer at the track.
Any leads appreciated. Thanks!
Obba
posted December 25, 2008 01:10 PM        Edited By: Obba on 25 Dec 2008 21:12
Not sure if you want to replace the headlight (weight saving), and you just need 'something' to light up the area for loading / unloading etc. But the 3W Luxon head strap torches are fairly bright, 50% as bright as a 50w halogen down light - but narrower beam.
With their elasticated straps, put two together and it'd be nice to slip them on and off when needed. Pretty tough as well. Also handy to pop it on your head for general walking a round if its dark etc.
3W version: Ebay 360118975169
5W, 75ft beam that would do the job, but pricey: Ebay 400016303409
If you are after to keep the headlight housing etc, then these guys might be able to help as they do LED headlights as well.
http://www.customdynamics.com/
posted December 25, 2008 01:29 PM
Thanks for the leads. I am actually looking for something that I can mount to the bike, within the fairing area. A very small unit to permanently mount.
Peno
Peno
posted December 25, 2008 07:07 PM
There are some small fog lights at Pep Boys.You can just use one and have a spare.
ZXLNT
posted December 26, 2008 02:57 PM
Perhaps trying replacing the city lights with some ultrabright leds. The big 10mm Radio Shack White leds are pretty bright. It will take a little fab work though, they aren't plug and play...
bawls
re-learning to ride
posted December 26, 2008 03:21 PM        Edited By: bawls on 26 Dec 2008 23:21
deleted... saw that customdynamics was already on here after posting lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
RexPoff
RexPoff
posted April 19, 2012 09:03 PM        Edited By: RexPoff on 20 Apr 2012 05:07
I want to make some 12v led strip lights candles with these and mix them in with the pvc kind. I can't wait to g4 led bulbs melt some hot glue on the container and see how well the votive still shines through.
The tube is rather pliable and I am curious to rgb led controller see if the hot glue melts it a bit.
Bigbore4
posted April 19, 2012 10:13 PM
Go to JP cycles website and look at the Acerbis headlight unit, it's got 2 x 20w high beams and two strips on each side of ten led's. I'm not sure about the candlepower, but I'm guessing it's pretty bright.
Audi is using led headlights on their cars now and I guess they beat the shit out of the Halogens.
TH1RT3EN
Trial And Error Control
posted April 20, 2012 04:15 AM
you might check out http://www.streetfightersbydesign.com/streetweb/libertek_page/libertek_pg.htm
I dont know if you can get them in white or not, but if you can it may be an option. There is a set in the classifieds currently but they are red.
Big Earl pearl
Get rich to this
posted April 20, 2012 05:54 AM
Try advance auto they have flex led lights made by alpena!
0.21997880935669 seconds processing time
