BIKELAND > FORUMS > ZX-14.com > Thread: 16/43 top speed? NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted December 21, 2008 07:31 PM
16/43 top speed?
neone have a verified top speed for 16/43 gearing? just wondering as me and a friend are having a lil debate.
thanks
07 LE bolt on bike
BobC
posted December 22, 2008 01:29 AM
About 183mph.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
kawboy81
Busa Eater
posted December 22, 2008 02:34 AM
thanks Bob! i told him after my gear change i had her up to 175 with a lil more to go before she tapped out and he was saying bullshit. neways i know i could always verify myself but its 12 degrees in memphis so ima take a pass on that
07 LE bolt on bike
NINJA12
posted December 22, 2008 08:21 AM
155 mph on my bike
bbirdxx2000
posted December 22, 2008 01:20 PM
same gearing differant question, how much will your RPM's rise @ 80 MPH. My tach is at 4,000 RPM stock gearing
9.96 @ 143 stock with flies removed
NINJA12
posted December 22, 2008 01:37 PM
I should have said without speedhealer!
fifth
The Magnificent Bastard
posted December 22, 2008 04:06 PM
I think I hit around 182-ish on mine, with speedohealer. I dont recall the exact rpms, but it seems like I am around or just about 5k for highway cruising.......
kawboy81
Busa Eater
posted December 22, 2008 04:37 PM
155? dude i had my speedohealer set at -15.2 and its dead on verified by gps and radar gun (friend) is a county boi. neways i was well over 150 i was in the neighborhood of 175-178 and i wasnt on limiter yet, with 16-43 gearing.
07 LE bolt on bike
masszx14
A mind beside itself!
posted December 23, 2008 04:55 PM
The top speed with 16/43 would be about 5-6 mph higher if you have
a 190/ 55 rear tire compared to 190/ 50
universal@mind
Peno
Peno
posted December 23, 2008 05:24 PM
Dyno runs at local shop bike hit 185.5 with 16/41.So 183 ballpark sounds right.
NINJA12
posted December 24, 2008 10:00 AM
Are you saying your bike is not ECU limited to 186 with stock gearing?
Using your 15.2 percent ......... 186mph - 15.2% = 157.73mph max.
Assuming your bike is limited to 186 stock, new tires, no clutch slipage nor wheel spin.
I think you just proved my point. Pull the speedohealer and try it again.
In a perfect world with 16/43 gears, max speed is 157 mph without speedohealer, 186mph with it set to show correct speed, rpm and hp limiter with it set for -50 %.
serius blk
posted December 24, 2008 10:27 AM
on the gearing commander site it says 187 at 11000 rpm. I think my rev limiter comes on at 11,5. If the rpm is acurate the mph would be 195 according to the site. Does anyone know if the tach has any error in it.
NINJA12
posted December 26, 2008 09:12 AM        Edited By: NINJA12 on 26 Dec 2008 17:13
Is that corrected with a speedo healaer or not?
Tach and speedo almost alway read high.
street racer
posted December 26, 2008 05:35 PM
Not to change the subject but what factors does the ECU use to determine the top speed and limit the speed to 186 or so? Does it read RPM, speed according to the speedometer or whatever? Does anyone know?
kawboy81
Busa Eater
posted December 26, 2008 06:28 PM
im just saying i had it verified by gps and radar..... to be accurate within a mph or so....and i was reading 175-178 on my speedo.... with 16/43 gearing. im not sure of the rpms as i try to focus on the road at speed but i know that i was NOT on limiter and i WAS over 155........im pretty sure my bike is no different and is limited to 186 just like everyone else......
07 LE bolt on bike
kawboy81
Busa Eater
posted December 26, 2008 06:51 PM
my gps saves the top speed, if i can get some decent weather tomm ill make a run and try to upload a pic of the screen of the gps..... i have no reason to lie, maybe my calculations are innaccurate on my healer maybe my speedo is off.....i just know what it read. nothing more.
07 LE bolt on bike
ninja12
posted December 26, 2008 10:35 PM
Kawboy, Re-read my post.
I'm not calling you a liar or saying you are wrong.
I simply want everyone to get the COMPLETE truth. You need a speedohealer to go over ~155 with 16/43 gearing.
Do us a favor if you get out for some testing.
Make a pass with 0 correction in your speedo, we can subtract 15.2% from whatever speed your speedo shows. Unpluged speedohealer if that's easier.
No pictures necessary, we'll take your word. OK?
FastestBusaAround
I eat Fish...
posted December 27, 2008 07:00 AM        Edited By: FastestBusaAround on 27 Dec 2008 15:01
With no Speedo healer -- my 16/43's did 168 GPS verified for about a minute. This on both my 06 and my 08. I'd bet with the Speedo healer it could have done 178+ easy.
FYYFF!!!
1badzx12r
posted December 27, 2008 04:26 PM        Edited By: 1badzx12r on 28 Dec 2008 00:28
just got home but 17/45 is 167mph (gps) at 10.0 rpm shift chip in a MPS shift box
16/43 =2.69
17/45 =2.65
ninja12
posted December 27, 2008 09:12 PM
Can either of you explain how you are getting around the 186 ECU limiter?
I only know of two way around this, modify the sprocket nut , or speepdohealer.
I hit 155mph at the track with my turbo @4 psi , then @ 8 psi went quicker but still
155 mph. Researching the problem I came up with ~16% gear correction. 186 mph -16%
reduction = 156mph.
Help me understnd what I'm missing.
MJ
posted December 28, 2008 03:15 AM
reduction = 156mph.
One thing I can tell you Ninja12 is that 186 on the speedo is not 186 with the 14's ecu. I had my speedo buried on my completely stock 14 and never hit the 186 limiter. I was kinda bummed because I figured once I hit the limiter I would know I'd went 186 So with my bike anyways the speedo doesn't seem to be the place the ecu uses for its 186mph calculations. I understand your point that lowering the gearing with the stock speedo would lower your actual speed, and theoretically make you hit the 186 limiter much sooner... even though the speedo would be reading MUCH higher. I think part of the problem is you're giving the stock speedo too much credit. Its horribly off at higher speeds, to the point of almost being useless. I know, I've gps compared it as well....its really a joke Even with a speedohealer and (multiple) gps corrected to read right on at 80mph, once you get into the higher triple digits its still way off there's no way to truly make the 14's speedo accurate in the high triple digits, your only option is gps for ultra high speeds and honest numbers
ninja12
posted December 28, 2008 04:16 PM
My speeds were measured at the track over several passes.
Looks like i got the only bike that's actually limited .
I have another ecu, I'll try it to see what's really going on.
0.40265798568726 seconds processing time
