BIKELAND > FORUMS > ZX-14.com > Thread: Torque spec for clutch spring bolts? NEW TOPIC NEW POLL POST REPLY
rACeRs
posted December 19, 2008 08:10 AM        Edited By: rACeRs on 19 Dec 2008 16:11
Im installing the spring spacers today and need to find out what the torque spec for the bolts are. And for the clutch cover.
thanks
9.1 @ 149 w/ 1.57 60' SWB
posted December 19, 2008 10:18 AM
Is your clutch slipping???
If not then why do you need the shims???
rACeRs
posted December 19, 2008 10:28 AM
Im hoping that it will help the clutch live a bit longer.
posted December 19, 2008 10:30 AM
How many passes did you get from the clutch?
Getting out of the clutch ASAP is the only way to prolong clutch on a 14
rACeRs
posted December 19, 2008 10:36 AM
Its still going strong at 50+ passes, just a bit of preventative maintanance. True getting it out asap is going to be the best for the clutch, but getting it out too quickly hasnt worked for me so I drag it some. Do you have those specs by any chance? Im pulling the cover as we speak.
thanks
posted December 19, 2008 10:58 AM
Dont know off hand for the 14...But the 12 is 8.8 NM - newton meters or .78 INCH lbs.
Not much different...
rACeRs
posted December 19, 2008 11:07 AM
thanks
posted December 19, 2008 11:12 AM
rACeRs
posted December 19, 2008 11:34 AM
Thanks Shane
billeason
posted December 19, 2008 02:56 PM
I dont know what rpm your leaving at but i have 300miles on my 06 all drag strip. When i pulled the clutch last week to look over the motor,it was a waste of time all looks new and the clutch was still at oem spec's. The 14's have one of the best clutches i have seen in a long time.
bill eason
Wheelie
Old Man
posted December 19, 2008 03:48 PM
if it aint broke, dont fix it. I had 100's of runs on my oem clutch.
wee
Smooth_G
posted December 19, 2008 10:56 PM
GOOD LOOKIN OUT SHANE
0.25001001358032 seconds processing time
