BIKELAND > FORUMS > ZX-14.com > Thread: has anyone had forks cut NEW TOPIC NEW POLL POST REPLY
jdrill04
posted December 17, 2008 09:17 AM
i sent my forks to coby adams to have them cut . i was just wondering if anyone has done it and how they like it ?
ratbyk
posted December 17, 2008 09:27 AM
? Why cut your forks?? You can easily drop the front by raising the forks within the triple clamps. If you drop much over 1" you are are into the front fender and have lost most suspension travel! Once you are into no/low suspension travel any bump at speed is at the very least going to get scary if it doesn't simply spit you off!!
rACeRs
posted December 17, 2008 09:31 AM
+1 you can get the front of the bike plenty low by sliding the fork tubes up between 1-1.25" and putting a strap on it. My front fender has marks to prove it
9.1 @ 149 w/ 1.57 60' SWB
FlatoutBu
posted December 17, 2008 09:46 AM
Well there are a couple benefits both ways. It's nice to just be able to slide the forks and strap it down...it saves money on having them cut and it can go back to stock. Cut forks are great when you need some suspension travel...not all tracks are glass smooth. (Mine used to have oil pan crushing pot holes in it until they resurfed'd it this year.) You also have a little more control over wheels spin with cut forks. The bike will transfer more weight back helping the rear plant a little harder. Where a strap will have the front tire on the ground or off....which means you have traction or you dont.
06 Blue 14
9.008 at 153mph @ 195 suited
rACeRs
posted December 17, 2008 10:05 AM
I didnt think of it that way, but once you get your bike long enough to where traction becomes a problem then cut forks could be a good thing to aid weight transfer. Something a stock wheelbase bike doesnt need to worry about.
Red1
posted December 17, 2008 10:34 AM
jdrill04,
I ordered the Schnitz front lowering blocks for my 14 which dropped my front end 1.25" and I have the dogbones on the rear at the middle hole ( 1.25"). I am stock wheelbase and do the occassional dragstrip day. I had the same setup on my 2000 ZX12. I like the lowered bike..it really helps with the wheelies plus from my personal experience it gives the bike a more planted feeling.
The suspension on the ZX14 is ultra soft ( to me ) anyway so with it lowered and stiffened it feels more solid to me. Can't carve the canyons lowered like you do at stock height but if you want to go that route I would get a ZX10 anyway!!
Red12/Blue14
jdrill04
posted December 17, 2008 12:02 PM
sorry guys, i should of gave a little more info. the bike is used only for the track. it is going to be a grudge bike. it is our time the busa guys have got to realize they have some competion. the bike is 64" , i want to do away with the strap. i may take the tire back to 66".
oldkawboy
posted December 17, 2008 01:31 PM
I know some folks who will cut the forks but Coby or Chip Hunter is the only two I would use.
You can't go wrong with either of them.
Dan
nicks14
posted December 17, 2008 03:32 PM        Edited By: nicks14 on 17 Dec 2008 23:34
i got my forks cut some months, it all depends on street use or strip use, im all strip so thats why i did it and it also allows you to get your front lower! i think you will like it sense its a track only bike!
hellraiser
johnsonzx14
posted December 18, 2008 07:56 PM
Some of my buddies forks had been cut by mcintosh..... Some were ok, and two of them that I know had leaking issues.....Im not cutting mine...
BobC
posted December 19, 2008 03:06 AM
Isn't it easier to fit shorter springs? No problem with front fender hitting the fairing and easy to return to stock if you sell the bike.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.26423001289368 seconds processing time
