BIKELAND > FORUMS > ZX-14.com > Thread: front sprocket removal NEW TOPIC NEW POLL POST REPLY
Newbusa
posted December 08, 2008 06:02 PM
Does the clutch slave have to be removed to take off the front sprocket cover?Or does it come off together in one piece?
smokinzx14
posted December 08, 2008 06:20 PM
All in one ...
bawls
re-learning to ride
posted December 08, 2008 07:18 PM
Hey Lee... can I put a 16t front sprocket on my bike and leave the 41 rear on without shortening the stock chain?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
smokehouse4444
XX to ZX
posted December 08, 2008 07:26 PM
That's why I went with the 16t instead of the 43 or 44 rear; I wouldn't have to mess with a new chain. Considering the torque differences that I have since learned about, I kinda wish I would have gone with the rear. Just my quick 2 cents.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
smokinzx14
posted December 08, 2008 07:48 PM
Yes put a 16 on .No chain to cut ...It will move the axle about an 1/2 inch back and will help with your 60 times .. You will love it trust me ..
bawls
re-learning to ride
posted December 08, 2008 07:53 PM
yeah, I have the feeling that that's what i need to get into the 1.5's with me being a fatty since thanksgiving lol 180 lbs.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Newbusa
posted December 08, 2008 08:25 PM
All in one ...
Hmmm,I guess the cover must be stuck on then,I removed the 4 long bolts from the cover and it does not budge,not sure if i should pry on it?I was thinking earlier on that maybe the bolts that hold the slave on maybe went through the main cover as well.Well maybe its time to get more aggressive.
xstatik121
posted December 09, 2008 03:17 AM        Edited By: xstatik121 on 9 Dec 2008 11:17
OK I actualy did this on Friday last week.... the ONLY bolt that goes through the clutch slave is the top one, the other 2 do NOT go all the way through. I loosened them all and pulled the cover off slow and noticed the other 2 dont go through and tightened them back up so I wouldnt leak any fluid, which saved me from bleading the clutch. Thats the way it is on my 07 anyway. only thing about it is its kinda in the way when trying to break loose the front sprocket bolt.... which is a bitch... make sure you eat your wheaties before you try breakeing it loose. and you might want another set of hands around when you do, unless you have a stout impact, which we didnt lol. One thing I noticed AFTER I got the sprocket bolt of is the washer that sets behind it is bent to lock in the bolt.
ok this might sound stupid but just for imformation. When you put it all back together make SURE you put the rear brake caliper back in its grove on the swing arm that keeps it in place... I wouldnt be mentioning that if I had done so. I didnt and now Im ordering a new brake line. Just glad I was going 5mph instead of 135 down the highway...
07 ZX14 Plasm blue~PCIII cust mapped~TwoBrothers dual~Vortex sprockets down 1 in front~BMC air filter~Lowered 2" in rear 3/4 up front~200 Metzeler~Roaringtoyz links, stand~Shogun sliders~~Puig DB...
posted December 09, 2008 08:08 AM
glad you got it done xstatik
xstatik121
posted December 09, 2008 02:14 PM
Thanks bro, and thanks for the help on Friday... So far for no more than I have rode it Im liking the -1 tooth up front. only thing is I need to watch what im doing when I get all into 1st. and second for that matter
Newbusa
posted December 09, 2008 10:03 PM
Thanks xstatik,The top slave bolt did go through the sprocket cover,got it off and mounted the 16 tooth on there.A little tough to do by oneself but far easier to put back on.Once again thanks for the advice.
lietoome
posted December 09, 2008 10:14 PM
Busa, guess it was the top, not the bottom. I knew it was one of them.
xstatik121
posted December 10, 2008 02:58 AM
Kool glad you got it Newbusa... yeah it was a bitch getting the sprcket bolt out huh?
0.22384405136108 seconds processing time
