BIKELAND > FORUMS > ZX-14.com > Thread: Exploded Clutch Basket NEW TOPIC NEW POLL POST REPLY
JohnnyRocketZX14
posted December 07, 2008 03:31 PM
well i think this is a new one, anyone seen this before on a 14? went to San Antonio and made a few passes Friday night to prepare for Saturdays races. This was the result on run #5
4 frictions were gone
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
JohnnyRocketZX14
posted December 07, 2008 03:34 PM
i would take any ideas as to what happened as well as suggestions on replacement ideas
07 ZX14
ratbyk
posted December 07, 2008 03:45 PM
This usually happens when the clutch is disengaged at extremely high revs and the part/parts disintegrate from centrifugal force. As long as the clutch is fully engaged the pressure springs hold everything together. Pull in the lever when the revs are in the strato-spher and ka-boom!
Lucky it only took out the clutch cover and not the crankcase!! Now you can buy one of those HD clutch covers. as well as a new clutch. Drag racing is abusive on equipment.
posted December 07, 2008 03:48 PM        Edited By: Shane661 on 7 Dec 2008 23:50
Send your gear assembly to Falicon and have them attach it to a billet basket.
Anything can happen when you put these kinds of stresses on the drivetrain. Perhaps the original unit had a casting flaw...or maybe it's time just came.
I have not heard of this being a common problem on the 14. It will be interesting to see what you find in the oilpan.
zxbob
posted December 07, 2008 03:54 PM
I think APE has a billet basket also !
That looks painfull.
Bob
zxbob
posted December 07, 2008 04:02 PM
They do http://zxzone.com/clutches.html
Bob
JohnnyRocketZX14
posted December 07, 2008 04:18 PM        Edited By: JohnnyRocketZX14 on 8 Dec 2008 00:55
anyone else running a billet basket? probably 500-600 runs on the bike cant complain too much, but i think several of you also have those kind of numbers or more also. It had to be my fault i had just mentioned before that pass how bullet proof these clutches are.
here is the story, first 2 passes were normal, next 2 something didnt feel right during the launch, it was fine in the pits normal feel and take off but at the line it grabbed and bogged the motor. I wasn't sure if it was me ( hands were very cold ) or the bike, so i had to make another to be sure, However pass 5 started perfect, no sudden grab, felt smooth and just as the clutch was fully released , throttel was pinned and BOOM
I cant help but think maybe i had damaged a fiber first?
07 ZX14
smokinzx14
posted December 07, 2008 05:01 PM
I have seen one other zx14 do that ( not near as bad as yours ).. It's something that doesn't happen offten but when it does it sucks ..Get a billet basket and make sure to pull the pan and get the rest of that crap out of there ...
I had one on a GS1000 come apart and took out the hole motor and left me with a nice little scar on my leg...
kawasaki_rick
posted December 07, 2008 05:33 PM
I got 2 extra clutch baskets. If you need 1, let me know, Ill sell ya 1 cheap, or trade ya something.
SteddyTeddy
posted December 07, 2008 06:18 PM
Go billet or expect it to happen again. For that basket to go like that, it has been cracked for a while. Smokin broke one on his ZRX and I broke 2 on my ZRX before I installed a billet basket. Pull the pan off that motor and check EVERYWHERE. You will find all sort of pieces hiding.
zxbob
posted December 07, 2008 08:11 PM
I have a new cover .... I can probably save ya a few bucks on !
Bob
posted December 07, 2008 08:48 PM        Edited By: CrotchRocket on 8 Dec 2008 04:51
That's rare, was there an air shifter malfuction???
How many times have you missed shifted???
When you use to foot shift did you use the clutch after 1st. gear???
posted December 08, 2008 05:29 AM
Yikes!
burnout
posted December 08, 2008 06:58 AM
Muzzy also sells one.
1/8 5.66@129.77
1/4 8.74@159.60
JohnnyRocketZX14
posted December 08, 2008 09:01 AM
No Malfunction
missed once in while when i was footshifting last year
the first couple of times i raced i did use the clutch (bone stock), didnt know any better. That was several hundred runs ago so not sure if that could have caused previous damage
07 ZX14
posted December 08, 2008 09:54 AM
How many times did you have to forcibly remove warped steels???
The steels must have been so warped that it caused the basket to blow!!!
JohnnyRocketZX14
posted December 08, 2008 10:02 AM
was only 2nd clutch, steels never warped, original steels slid right off so did these, u can see in the pic they dont look bad and are not warped at all
07 ZX14
posted December 08, 2008 10:17 AM
What clutches plates did you have in there, OEM set up...
What springs???
Using Nitrous???
JohnnyRocketZX14
posted December 08, 2008 10:44 AM        Edited By: JohnnyRocketZX14 on 8 Dec 2008 18:44
muzzys http://www.muzzys.com/ZX14/ZX14_clutch_repack/index.html
Brocks springs
used nos several times, not on this day however
07 ZX14
SteddyTeddy
posted December 08, 2008 11:32 AM
Doesn't matter what plates or springs you run. Once the webbing between the basket fingers starts to crack it's only a matter of time before it blows. The clutch basket takes an enormous amout of TQ to lauch the bike. Stock baskets are just not made to take that kind of abuse continuous. Go billet and nerver have to worry about it again. Oh and I'm serious about pulling the bottom off that motor.
JohnnyRocketZX14
posted December 08, 2008 01:24 PM
going to drop pan tonight and try to get it all cleaned up.
Any tips or trick on how to get the Basket off with out a impact?
07 ZX14
flite leader
posted December 08, 2008 01:40 PM
it aint like a billet wont let go
& if it does it will throw bigger chunks at you
the imperative question is how long since last clutch rehab
how long since plates ...... steels or friction were replaced
a reasonable estimate of how many passes are made
you can SEE the clutch basket getting beat up........
you can also feel it by running your fingers across the tabs
on removing the big nut ...................................use a breaker bar & keep it 90degrees
sometimes it gets off angle & can cause further problems
it is improper to use an impact......................sure it gets the job done
except it knackers the threads .........................resulting in a less likely
situation that your torque of the reapplied big nut will be correct
that applies to ANY fastener !!!!!!!!
if you want it to be right ..........
or stay right
IMPACTS ARE NOT USED
good mechanics know this...... great mechanics do this
bend your mind.....
or break your ass...!!
JohnnyRocketZX14
posted December 08, 2008 02:49 PM
or stay right
Well thats what i am using, need to stop the engine from turning over, Tried brake/ maybe i need a helper to hold it, i only tried for a second it was getting late
07 ZX14
Halvefast
posted December 08, 2008 05:26 PM
Johnny, just looks like it was time to go, those stells look to be in good shape.
Billet basket, OEM clutch plates, and get an assortment of steel thicknesses
so you can get the stack height just right.
Good meeting you!
ECTA Ohio Mile 195.132mph
JohnnyRocketZX14
posted December 08, 2008 06:19 PM
Good meeting you!
Nice meeting you as well
PM sent
07 ZX14
0.25203919410706 seconds processing time
