BIKELAND > FORUMS > ZX-14.com > Thread: rubber mat around motor?? NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted December 05, 2008 11:12 PM
can anyone tell me the purpose of that rubber mat around the motor? sound dampening maybe? i mean to me it looks like a heat blanket! or maybe to keep heat in from melting plastic? can i take it off? anyone done this noticed it running cooler? i dont have a manual so i havent a clue what it for......
07 LE bolt on bike
BobC
posted December 06, 2008 12:24 AM        Edited By: BobC on 6 Dec 2008 08:30
If you mean the rubber inserts between the fairing lowers and the engine, they're to stop the hot air from cooking your legs. Stuff stuck on the inside of the panels is usually sound deadening unless it's silver coated which is to reflect heat.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Cajunboyz
posted December 06, 2008 05:30 AM
I think he's talking about the the thin rubber sheet over the motor???
posted December 06, 2008 05:49 AM
I removed mine. Should run cooler, and noisier...but I've not really noticed it:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=40269&pagenumber=3
posted December 06, 2008 03:59 PM
noise isnt really an issue with anything except stock pipes
kawboy81
Busa Eater
posted December 06, 2008 04:14 PM
yes Shane thats what i was referring to! it seemed to be a dampening effort rather than a heat reflector. as stated a heat reflector shouldve been aluminum backed right? im not worried about a little more noise that muzzy M10 will take care of that. Ill remove it and note any temp changes for anyone interested. Thanks Shane
Brad
07 LE bolt on bike
0.21867179870605 seconds processing time
