BIKELAND > FORUMS > ZX-14.com > Thread: oil sensor problems NEW TOPIC NEW POLL POST REPLY
bayou boy
posted November 22, 2008 02:42 PM
oil sensor problems
having problems with oil sensor, keeps flashing, we've done every thing,ck rods ,drop oil pan,every thing, only thing i can think of is the pk up was so dirty,it was block,an the sensor itself was dirty, my old mech assured me he was cleaning oil pan, everytime we burnt clutches,an spint bearins, i guess he lied, man my sensor had depri in it.. it's just keeps flashin, has this every happen to anyone before.
wrongway
posted November 23, 2008 04:56 PM
can yhou hook up a mechanical guage to verify the pressure?
Roy
ninja12
posted November 24, 2008 04:42 AM
What RPM does your bike idle? set it atleast 1000.
Have you checked the pan yourself? I'd check the sensor wire, then manually check pressure, pull pan for trash, clean pickup, then pull oil punp in that order.
It's easy to swap the sensor, or go to walmart automotive section
get a mechanical oil pressure guage for less than $20.
Put it in place of you pickup or testing.
These are not MAC TOOLS but they work well for jobs like this.
I don't think your sensor can get too dirty to work, you bearings would give up long before that.
zx13r
Capt-America
posted November 24, 2008 08:49 AM
Check pressure with a gauge, if good, could be a short in the wire. I pinched mine between the motor and sprocket cover.
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
kawpower
Mr kawasaki 2 you!
posted November 24, 2008 10:59 AM
Debri in the oil sending unit, been there before.
bayou boy
posted November 24, 2008 05:03 PM
we ck everything, it seems pinch,cause we ck bearings,an everything,just flashin ..
ninja12
posted November 24, 2008 09:34 PM
Are you saying you had trash in your sensor?
That sensor screws into the cases on the end of the oil valley that feeds the crank.
If you had trash it would also be feeding into the crank, and bearing life would surely be low.
That oil should already be filtered.
kawpower
Mr kawasaki 2 you!
posted November 25, 2008 06:41 AM
It was there, lite came on after motor build ,would fash on off , checked eveything found nothin, took unit off, placed on white towel sprayed inside with carb cleaner and debri came out , installed unit no more lite.
NINJA12
posted November 25, 2008 07:29 AM
Bingo, that explains it.
You could get trash in there somehow during a rebuild, but not doing normal operation.
It also could have be left over from when the engine blew.
kawpower
Mr kawasaki 2 you!
posted November 25, 2008 01:15 PM
just trying to help.
bayou boy
posted November 25, 2008 04:27 PM
thanks,
ninja12
posted November 25, 2008 10:11 PM
Please don't take my comments the wrong way.
I'm just trying to help also.
Most of us are still learning , I didn't understand how that could happen until you explained.
Discussion help everybody.
0.2444269657135 seconds processing time
