BIKELAND > FORUMS > ZX-14.com > Thread: 240 in a Stock ZX-14 Swingarm NEW TOPIC NEW POLL POST REPLY
bijan
posted November 12, 2008 07:59 PM
first off let me start out by saying whats up to everyone out there being that this is my first post. i saw this on blingrockets.com and they were saying that you need offset sprockets to make it work. http://forum.blingrockets.com/showthread.php?t=235&page=7
does anyone know what sprockets to use, and has anyone else done this. any help will be greatly appreciated. btw i ride an 06 zx14 chrome muzzy's chrome rims black on black, pics will be up soon
black 06 zx 14, roaring toyz black links, voo-doo slip ons, chrome wheels, and chrome frame plugs, and tre
smokinzx14
posted November 12, 2008 08:15 PM
I'd give Roaring Toys a call ...
smokinzx14
posted November 12, 2008 08:16 PM
Allmost forgot ....................WELCOME
posted November 12, 2008 09:07 PM
roaring toyz
kawabonzai
Leader of the Back.
posted November 12, 2008 09:31 PM
I thought you were talking about 240mph with a stock swingarm.
I need to learn to pay attention.
2009 ZX-14 Candy Lime Green
posted November 12, 2008 10:49 PM
you may like the look, but its going to slow you down and make cornering harder
1badvespa1400cc
power junkie
posted November 13, 2008 06:54 AM
If you do that with a stock swingarm the wheel will sit offset to the right.
Just another foeteen!!!!!
Halvefast
posted November 13, 2008 05:37 PM
Check with Kosman, I hear it is like only $800 that is widening your wheel too
ECTA Ohio Mile 195.132mph
THEMADKAW
posted November 13, 2008 11:00 PM        Edited By: THEMADKAW on 14 Nov 2008 07:05
Kosman does it for a lot less than Roaring Toyz, Roaring Toyz told me $2500 and exchange my stock wheels! Kosman says $850 for mod of your wheel(refinish not included) and that includes sprockets. gonna do mine this winter hopefully, so if i don't like it, just put another stock wheel on it and keep on movin!
but one thing is for sure, if he widens it to 8.5", its gonna be REAL tight!!!!!
and its gonna be dead center of the arm, no other way!
kawboy81
Busa Eater
posted November 14, 2008 02:13 AM
so the 2500 dolla ticket from roaring toyz was for widening the stock wheel only?
07 LE bolt on bike
THEMADKAW
posted November 14, 2008 05:30 AM
i was told price includes: both front and mod. rear, (in chrome),fr. and rr sprockets, and rr tire. and i would have to send them my stock wheels.
they told me it would be @ 2200 when i spoke to them at BBW, then i was so knew they hadn't priced it yet, after i called them a couple of times in june and july, they nailed the price down at 2500! i didn't tell them i had already called Kosman and gotten his price (850, includes both spockets also).
i can't be upset with' em for making money,
I just can't afford 'em !!!! LOL
1badvespa1400cc
power junkie
posted November 14, 2008 07:54 AM
Yeah but do you want the wheel centered,beacause every kit I have installed and have seen are always offset to the right.
THEMADKAW
posted November 14, 2008 12:33 PM
yuo definately want it centered, if you can get it centered. most bikes are off-set because you can only push the chain and spocket so far to the left. the 14s i've seen have the wheel (240) almost perfectly centered, even with longer arms. bigger tires are always centered because they run Jackshafts.
1badvespa1400cc
power junkie
posted November 15, 2008 04:40 PM
Yeah I dont like almost centered,it needs to be just like the factory just my 2cents.
totall2tall
posted June 12, 2010 07:34 PM        Edited By: totall2tall on 13 Jun 2010 03:39
zx14 stock swing arm with 240
get rim widened from east coast motor sports call jonathan at 1 704-786-8820 tell him travis told you to call send him your rim he will widen it. ask for a 11mm spacer for sprocket only. thats the only spacer you need. get a 1/4 inch offset sprocket. new bearings for your rear tire. get a 15 tooth since the rim will now be a18 inch rim instead ofa 17. get a pirelli tire. take your rear brake calper holder on rear where where it goes on axle nut and grind like 1mm off. use locktight on everything when you put it back together. call kawasaki shop in your town and ask for torque specs and torque all bolts. if you do this the tire is not off set. and i run 180 mph and does just fine. all you need is 1/4 inch offset sprocket, 11mm spacer between wheel hub and sprocket and put new bearings in.
biggmoinc
posted June 13, 2010 01:29 PM
Everything sounded right but all they do is widen the rim when they do the rear, so why is it an 18 now instead of a 17, i got a 240 from roaring toyz over 4 years ago n the setup did include a 18 on the back instead of the 17 n 1 tooth down offset in the front, but a friend had his rear wheel widened by tripleplatecustoms n the wheel is still a 17, (this bike is a katana 600 too) the chain will ride dangerously close to the frame however, not sure how close it is on ur 14's, i've seen some notch out the frame for clearance, but my 240 is centered n 51pds heavy, lol
biggmo@aol.com
totall2tall
posted June 14, 2010 12:38 PM
i sont know why the rim is a 18 now the lips they weld on make it bigger and i went one tooth down beacause the tire got biggger round you dont have to go a tooth down and no there is no notch in my frame my tire is center and i go 180mph and if therer was something wrong the bike would break at that speed. its close to tire and frame but i got everything even painted for 1,100 dollars. those fags a triple plate custom are ripping everyone off and i told them i would figure all this out and tell everyone how to do it so they dont make a pisss load of money off all of use for something this simple
totall2tall
posted June 14, 2010 12:40 PM
tell me to fuck off now triple plate. now everyone nows how simple it is with half the money
Jason Gillum
posted June 14, 2010 01:06 PM
I would call Angel from Sparling Image Custom Cycle (302) 633-9130...I believe they were the first to do this type of thing...I could be wrong.
Brock's Performance...
totall2tall
posted June 14, 2010 02:08 PM
why theylle charge the hell out of you when you can get your rim widend for 500. dollars and get a 11mm spacer from a machine shop for like say 50 to a 100 dollars new bearings like 50 dollars 1/4 inch off set sprocket 89.00. torque wrench borrow one or therer like 60 bucks. lock tight 5.00 dollars, 6 bolts for spacer at hardware store make sure there 6 grade bolts like 8.00 dollars. perille zr tire 190.00 mount balance at bike shop 40. dollars, get rim painted at local body shop like 125.00 dollars. add that up thats cheaper than what eny one else will do for you and you have to put the rim and kit on yourself anyways if you get it from them. i done this in the winter as a project it takes like 4 weeks to get your rim back. and like a week mabye to get it painted if there busy. and you can by the bearings and sprocket on ebay new. and you got jonathans number he will get you a spacer and hes the one that wideneds your rim. your not paying a middle man. in no way am i afiliated with any of these people i live in south dakota im just beaing nice trying to save all my zx14 rides some money. dont pay the middle man.
biggmoinc
posted June 14, 2010 02:20 PM
yeah mine went to a 18 n went -1 in the front n a 46T in the back, this kept the rollout bout stock. Now i ride wit a 49T on the back n its like riding around all the time in 5th gear, lol, but it pulls good, probably much similar to everyone going down 1 in the front n up 1 in the back. I think my speedo is like 6mph off at 65 n a little more at 160
biggmo@aol.com
totall2tall
posted June 14, 2010 04:15 PM
yeah i lost a little in the top end 6mph but gps says im going 180 and seems to have same power all around i gota ivans tre 008 on my bike the best 80 bucks youll ever spend
biggmoinc
posted June 14, 2010 04:20 PM
yeah, but i'm probably going back to the stock gear ratio, i just want to try n get some lower et's out of the bike, now i need a back tire cause i had to put that metzler 880 back on it since my diablo showed steel, lol, that 880 will spin in 4th gear, lol, j/k, but it is a touring tire n not a traction tire. After i get the tire i'm going to sum test n tunes, wish i had a tune on the bike but summer is already here, unless i get a raise, it'll be undertuned this year as well, lol, but i would luv to go to JMillers class at MIR someday I saw a 240 on a 14 running 9.50 index, if i cant get to that i would b happy
biggmo@aol.com
totall2tall
posted June 14, 2010 05:29 PM
we only have 8th mile track in sturgis and i have not ran my 240 yet this year but its fun going to grudge matches on wed nights its like a test and tune but funner. not many bikes racing here. and cant run with a car but for 20 bucks you can get in line all night and run down the track 5 hours or so its fun i spin out alot with the 190 tire hoping to get better time with my 240
posted June 14, 2010 08:03 PM
Where you getting the offset sprokets?
Do you have pics of your bike with the 240 on it? is it DEAD center?
Thanks fo sharing
0.29795098304749 seconds processing time
