BIKELAND > FORUMS > ZX-14.com > Thread: raptor shift light NEW TOPIC NEW POLL POST REPLY
06redzx14
posted October 02, 2008 09:27 AM
raptor shift light
What is the best tach feed for the shift light?
jarhead
posted October 05, 2008 05:24 PM
I use the number four coil wire. Have been running the light all year and it has been good.
06redzx14
posted October 05, 2008 06:09 PM
I can't get it to work. currently the switch is set to 2 it shows four cylinder mode. 5 on the 1000 dial 6 on the 100 dial, but it hasn't come on at that rpm ???
06redzx14
posted October 07, 2008 06:25 AM
anybody?
jw
posted October 07, 2008 08:36 PM        Edited By: jw on 8 Oct 2008 04:37
If you wire it to a single coil on plug, you have to set it for 1/2 pulses per rev or all three dipswitches off.
Edit- it also means that the highest you can set it is 10000rpms.
0.24479508399963 seconds processing time
