BIKELAND > FORUMS > ZX-14.com > Thread: 06,07,08 ZX-14,Can u tapp into the OEM shift light & use another LED light? NEW TOPIC NEW POLL POST REPLY
Cajunboyz
posted September 25, 2008 04:13 AM
Was wondering if you could tapp into the shift light(maybe somewhere on harness to ECU ?) & use just another LED light?? You would have a brighter light & still set it the original factory way??
06redzx14
posted September 25, 2008 05:42 AM
from what I hear the OEM shiftlight is a mini led attached to the circuit board inside the gauge cluster and cannot be tapped
ZXLNT
posted September 25, 2008 06:32 AM
If you can find the proper connection on the ciruit board then yes more than likely you can.
jdzx14
posted September 25, 2008 09:40 AM
U could find the soldered connection and solder a wire to it but then you would have to run it between the gauge top cover and bottom cover, which could damage the seal and cause it to leak water into it, i have had it apart several times, i put blue LED's in mine, its fairly simple though.
2007 Black ZX-14
billeason
posted September 25, 2008 04:20 PM
Cajunboyz, i was going to explain on another site about soldereding the board but i get some one trying to bait me over there,for what reason i don't know'' but i did a little fishing myself with a responce that means nothing. I want to see what the reaction is. I was going to pm you and let you in'but saw this instead.... Bill..
bill eason
Cajunboyz
posted September 25, 2008 05:22 PM
Again thanks Bill; Just PM me if you get anything
06redzx14
posted September 25, 2008 08:29 PM
jdx, do you have any pics of that panel back light?
0.31449794769287 seconds processing time
