BIKELAND > FORUMS > ZX-14.com > Thread: (Pics) Faster, Sounds AWESOME, Cost me 14 Bucks! NEW TOPIC NEW POLL POST REPLY
NYC ZX-14
Manager Star Toyota Bayside,NY
posted September 23, 2008 01:38 PM
I just mounted a 3A Racing (car) muffler on my bike purchased through e-Bay for $14.00 and WOW! The sound is nothing short of INCREDIBLE! Three other guys have said it is by FAR the best sound they've EVER heard out of a race bike. I'm experiencing amazing torque and seat of the pants horsepower (Feels faster and definitely more powerful than the stock cans (even when gutted)). My bike is faster and lighter.
IMHO it looks great and saves a bunch of weight and I can't believe it turned out as well as it did! lol
Here's what I did:
1: Remove the old pipes.
2: Plug the left side opening at the collector.
3: Cut the bracket off the stock left can and rivit to the 3A Pipe.
4: Cut the factory midpipe right where it enters the factory muffler
5: Notch the front of the 3A muffler pipe so the installed clamp will "crush-fit" it to the factory stock midpipe.
6: Mount the new pipe and enjoy!
I'll post a sound clip soon.
Currently?
2007 Kawasaki ZX-14, 1999 Kawasaki VN 750, 1976 Suzuki RE-5 Rotary
http://www.goldiesplating.com
  Ignore this member    Click here to visit NYC ZX-14's homepage.
flyboy
posted September 23, 2008 01:42 PM
Looks great--
"The World's Fastest Indian"
One fast red ZX-14,
Ninja_Knight
posted September 23, 2008 02:01 PM
Wow! That is a BIG HOLE!
street racer
posted September 23, 2008 02:02 PM        Edited By: street racer on 23 Sep 2008 22:05
Nice job !!! Cant wait to hear the sound clip. How about a few details on how you blocked the left side of the collector ? Also is there one specific 3A muffler that fits the exhaust pipe or are they all the same. Thanks for the info!!!
Tool Man
posted September 23, 2008 03:59 PM
You should go bigger...
The banks are failing..
The banks are failing...
Invest in Ammo
NYC ZX-14
posted September 23, 2008 04:02 PM        Edited By: NYC ZX-14 on 24 Sep 2008 00:19
Yep, 4.25" Outlet lol. Actually, for the entire length it's only 2" INTERNALLY.
After the "pinched" area near the rear the bell opening is 4.25" but the pipe is, in effect, your standard 2" "straight-thru" pipe with sound absorbing walls.
Currently?
NYC ZX-14
posted September 23, 2008 04:10 PM
The soundclip is here: http://www.goldiesplating.com/Kawasaki/ZX143APipe.mp3 You should be able to right click and press "save as".
The left side was blocked off by finding an aluminum "endcap" for pipe capping that I had lying around that was the same size as the factory hole, then cutting 1/4" slits with a dremmel cutoff wheel into the edge of the factory opening so it would spread when the endcap was hammered GENTLY backwards into it. I used a small rivit to secure it even though that's probably not necessary given the tight fit.
Note that the factory collector's opening is slightly "pinched" narower at its opening so this inner "lip" was ground flat FIRST.
I would guess ANY 3A pipe will fit that has a 2" inlet. The one I used was a 63-0544.
Currently?
Hawkman
posted September 23, 2008 04:24 PM
LOL I gotta give you props for the work you put into it, but that's just too much rice for me.
A fart can on a ZX-14. LOL
street racer
posted September 23, 2008 05:20 PM
Thanks for the extra info and the sound clip is awesome. I just finished ordering one for myself. Should be lots of fun and another reason to spend more time in the garage...ha !
derpie
Dont judge a book by its cover
posted September 23, 2008 06:06 PM
Why not put two cans on and get double the sound. duals are where its at sound wise. you dont see 5.0 or cobras or vipers or vettes with one xhaust
derpie
just my two cents
bawls
re-learning to ride
posted September 23, 2008 06:16 PM
You also don't see them with 1.35L engines in them. 4-1 is where it's at on small engines.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
warbird
posted September 23, 2008 06:29 PM
I'd Rather Be Roadracing.
NYC ZX-14
posted September 23, 2008 07:04 PM
Wanted to TEST it on one first, will experiment with the second another time. I was also worried about having WAAAY too little back pressure with two "straight" pipes and not re-mapping for fuel-air mixture since just one 3A pipe allows more flow than BOTH stock cans combined.
Currently?
NYC ZX-14
posted September 23, 2008 07:06 PM        Edited By: NYC ZX-14 on 24 Sep 2008 03:06
I don't know dick about engines as far as mods go (what's safe/good/bad/etc), but that's what I figured too.
Currently?
bawls
re-learning to ride
posted September 23, 2008 08:03 PM
There's a reason why none of the drag racers run duals.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Superman T
posted September 23, 2008 10:47 PM
Different...
gilberjj
Friend of Fast
posted September 24, 2008 12:43 AM
usually if i disagree or dislike something, i respectfully hit back without commenting, but i can't this time. I have to say that your exhaust is terribly ugly. I'm glad you're happy with it, but performance can't possibly be enhanced when you are squeezing double the exhaust through that mid pipe, plus you plugged the second pipe AFTER it has already done a Y.
MJ
posted September 24, 2008 01:12 AM
Duals give you more low end and midrange. 4-1 gives you the most peak power. So if your at high revs all the time (racing) a 4-1's the best power maker. A 4-2-1 system gives you a little more low/midrange with good peak numbers. A 4-1-2 (stock 14/busa set-up) gives you the most even spread of power....but gives up a few peak ponies to do it
street racer
posted September 24, 2008 05:24 AM
After I gutted my stock cans, I temporarily plugged the left side of the collector and went out for a ride with just the right side can installed. Remember it was gutted. Anyway, it was way too loud for me with just the one can. On the way home my temporary plug blew out of the collector and it got really loud !!! I bet with two of the 3A,s installed the sound would be deeper and even more mellow. Maybe I will try two down the road just for kicks. I really like the looks of the 3A. Two might look and sound even better. Yeah...I know...I am a redneck !! Thats what happens when you live in SW Missouri !!! Thanks again NYC...I appreciate your time and info !!!
GHOSTMAN
posted September 24, 2008 05:38 AM
NYC ZX-14, is it possible to get full pics of the bike.
Kinda hard to see what you're working with.
Still nice to see something different.
I'm There Whether You See Me Or Not.
NYC ZX-14
posted September 24, 2008 11:29 AM        Edited By: NYC ZX-14 on 24 Sep 2008 19:32
Bet you're just PISSSED you spent thousands on your:
"Tsukigi full system, pipercross race filter, pcIII " LOLOLOL
And yes, performance CAN be enhanced since the exhaust flow is HIGHER now given there are no cats or baffles to restrict the flow like there were in the stock cans.
Currently?
NYC ZX-14
posted September 24, 2008 12:20 PM        Edited By: NYC ZX-14 on 24 Sep 2008 20:35
Here ya go:
Currently?
posted September 24, 2008 02:18 PM
we do have several exhaust sponsors who can help you out with a proper system when the time is right for you.
Bently
2012 14r In Blue and no Mods!
posted September 24, 2008 02:36 PM
To each his own and if you like it that's all that matters, but I would rather run stock If I had to.
All times are America/Va [ This thread is 4 pages long: 1  2  3  4     Next» ] < Previous Thread     Next Thread >
0.25015592575073 seconds processing time
