BIKELAND > FORUMS > ZX-14.com > Thread: Sidewinders/Street Clearance/Photos? NEW TOPIC NEW POLL POST REPLY
posted September 18, 2008 02:53 PM
I know that a sidewinder is not a good choice for the street. That being said, I have no problem cruising around on this bike, with the large air filter sticking out of the side:
Is a sidewinder worse than this at the header? Or does it drag the muffer more? If anyone has some pictures from a similar angle, that would be great!
posted September 18, 2008 02:58 PM
Ohh yeah...
Get a sidewinder and watch what happens when you make the right turn at the end of the 1/4 @ MIR...
Actually I should say listen to what happens!!!
posted September 18, 2008 02:59 PM        Edited By: Shane661 on 18 Sep 2008 23:03
Ohh yeah...
I usually see the guys make a long u-turn before heading back up...
I'm interested in which drags first, the megaphone or the header?
smokinzx14
posted September 18, 2008 04:24 PM
The megaphone hits first and trust me you don't have to lean far to make it hit ....
posted September 18, 2008 04:28 PM
posted September 18, 2008 04:30 PM
I wonder how it would be if you did away with the megaphone and ran it up to a standard muffler?
smokinzx14
posted September 18, 2008 04:36 PM
Then you end up with a Brocks Alien head.....
posted September 18, 2008 04:37 PM
wouldn't you be back at a gen3/smeg design with a big curve anyway
posted September 18, 2008 04:39 PM        Edited By: Shane661 on 19 Sep 2008 00:41
No...you would be able to use the Adams lowered oil pan. And you could drop the pan without removing the exhaust. Those would be the two main reasons I would want a sidewinder.
smokinzx14
posted September 18, 2008 04:43 PM
True but the power is the same ..
posted September 18, 2008 04:46 PM        Edited By: Shane661 on 19 Sep 2008 00:46
I think you will see more benefit from the lowering of the bike (with the Adams pan), being able to launch harder, than the few hp gain. What do you think, Lee?
smokinzx14
posted September 18, 2008 04:55 PM
True that's why Brock made it so you could get lower ... But if you want it lower you need to knoch the swing arm or get an aftermarket swing arm that has a cut out for the fuel pump ... You will also need that tiger under tail so the tire doesn't rub ... ...
sure physically it can be done - but what would you gain??? why not just use a gen3/smeg instead of reinvent the wheel
posted September 18, 2008 05:00 PM        Edited By: Shane661 on 19 Sep 2008 01:03
I know it's not just a bolt-on affair. I think everyone likes the idea of getting lower, but the sidewinder is apparently too much compromise for any street riding. I already plan to add the tiger tail, and I was considering gettting a notched arm at some point.
Pulling the oil pan today got me to thinking....
posted September 18, 2008 05:01 PM        Edited By: Shane661 on 19 Sep 2008 01:02
If you were dragracing or had to pull your oil pan in order to check for clutch debris, you would understand.
posted September 18, 2008 06:00 PM
Shane, thats not going to happen again!!!
BlackMagic14
I have a swingarm if you need one let me know. Velocity Prostreet Powder coated black with Black VR chain gaurd
smokinzx14
posted September 18, 2008 06:31 PM
PM me with a price on that arm ....
1badvespa1400cc
power junkie
posted September 19, 2008 05:20 AM
I have a muzzy sidewinder that I bought from lee awhile back and have only tapped it once when I first got it.I usually turn the wheel a little more and keep the bike a little straighter and have no problems.
Just another foeteen!!!!!
posted September 19, 2008 05:35 AM
You ride it on the street? How much is the bike lowered?
johnnyrocketzx14
posted September 19, 2008 01:50 PM        Edited By: johnnyrocketzx14 on 19 Sep 2008 21:52
i ride on the street, mid hole muzzy links..i have no problem , but i dont do fast corners to the right anymore. been on for a couple months now and havent scraped it yet. i do plan to drop to the lowest position and think it will be a little more sensitive to right handers( like slow and vertical only)
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
Halvefast
posted September 20, 2008 08:16 AM        Edited By: Halvefast on 20 Sep 2008 16:17
Shane you could get a little more clearance with the Muzzy M-14 sidewinder, checkout Ninjaboy's bike,
the pipe is right up against the peg compared to Smokin's pic with the Brock's pipe
ECTA Ohio Mile 195.132mph
countersteer
Didn't read the owners manual
posted September 20, 2008 10:54 AM
i thought your shit got stolen?
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
posted September 20, 2008 11:06 AM        Edited By: Shane661 on 20 Sep 2008 19:25
Yeah, I was thinking M14 Sidewinder. I took some measurements today. If you run a 2" pan and a straight link you can drop the bike about 1 3/4" in the front (fender clearance might limit this) and less than 1" in the rear, when compared to a standard setup with the drain plug moved.
Actually that Brocks doesn't look too bad either, thanks for the pics!
0.34752202033997 seconds processing time
