Shogun
posted September 15, 2008 04:48 AM
Extended swingarm - battery relocation
Is anyone using a battery box in their extended swingarm (like a McIntosh)? If yes...what cables do you recommend and what length did you buy.
Thanks in advance for the advice!
Shogun
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
posted September 15, 2008 05:30 PM
why would you want to relocate the battery?? wouldnt you want the weight more up front?
kawasaki_rick
posted September 15, 2008 06:18 PM
maybe he wants a secondary battery, to start a stroker or? Thats all i could see it being an advantage for.
bawls
re-learning to ride
posted September 15, 2008 06:20 PM
maybe he's coming from the car world where more weight near the rear tire equals more traction.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Shogun
posted September 16, 2008 04:07 AM
My swing-arm came with a box to relocate the battery...I guess the asumption is moving the weight lower and a little further back has some advantage. If it doesn't I'll just put a lid on the box and presto...a ZX with a glovebox!
Thanks!
shane661
posted September 16, 2008 04:13 AM
Placing the battery lower will lower the center of gravity, making the bike less wheelie prone.
posted September 16, 2008 11:51 AM
quote: Placing the battery lower will lower the center of gravity, making the bike less wheelie prone.
o, i was assuming that having the weight more foreward would make it less weelie prone, but i do understand its better to lower the center of gravity.
posted September 17, 2008 02:23 PM
Have got a Mac arm with battery box, but have not wired it yet....
posted September 17, 2008 02:53 PM
no, the battery will be better as ballast where it is stock, or further towards the front. at the back even tho its low, its not as good. the further ahead the ballast is the higher it can be to still be effective, but ahead and down is even better.
mount a small battery in the swingarm if you need extra power from a second battery (24v start maybe or big electronics)
posted September 17, 2008 03:18 PM
Edited By: Shane661 on 17 Sep 2008 23:21
quote: no, the battery will be better as ballast where it is stock, or further towards the front. at the back even tho its low, its not as good.
That -may- be true on the 12 and 14. However, on the vast majority of bikes you will find that the stock location of the battery is above and rearward of the swingarm pivot. Lowering the battery in that case should be an improvement.
