BIKELAND > FORUMS > ZX-14.com > Thread: Clutch Spring Spacers?? NEW TOPIC NEW POLL POST REPLY
shane661
posted September 06, 2008 03:45 PM        Edited By: shane661 on 6 Sep 2008 16:57
Does anyone have the Brock's spacers laying around? I am trying to justify why 5 washers cost $30. There must be more to it than meets the eye...
Can you get the same result just shimming with standard washers? It seems like you would have even better tuning capability if you used washers similar to what you tune a lock-up with.
I'll probably end up buying the Brock's, but I'd like to learn a little along the way.
smokinzx14
posted September 06, 2008 04:35 PM
Brock spacers are 180 thou thick and looks nothing like washer ... I tried to find washer that would work but i had no luck so i got brocks spacers ..
shane661
posted September 06, 2008 04:39 PM
From the picture, it looks like they install on the underside of the spring?
smokinzx14
posted September 06, 2008 05:11 PM
They install under the factory washer at the top of the bolt .....
posted September 06, 2008 05:14 PM
would normal washers have the same tolerance for thickness?. the MTC shims i have are damn accurate
Nelson Taylor
posted September 09, 2008 06:59 PM
Hate to bring this back up, but did anyone else find the clutch way too tight/stiff after installing these spacers?
I have had no luck with the spacers. Maybe I am donig something wrong.
They intsall in between the spring and the factory washer correct?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
smokinzx14
posted September 09, 2008 07:26 PM
I run 3 of the spacers and it works well for me ... I tried all 5 but it was just to much for me ...
They intsall in between the spring and the factory washer correct? That would be correct ...
Nelson Taylor
posted September 09, 2008 07:37 PM
Thanks Smokin I'll give it a try tomorrow.
Best #'s
1.54
4.03
6.02 @ 121mph
madboost
posted September 10, 2008 05:00 AM
i run all 5 and love them.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
06redzx14
posted September 10, 2008 05:17 AM
I like all 5 HD springs
shane661
posted September 10, 2008 02:55 PM        Edited By: shane661 on 10 Sep 2008 15:56
Well, I got the Brocks spacers today:
I also ordered a spring tester off of Ebay:
At first glance, the Brock's spacers look like nothing special. In fact, I don't like the design at all (but hey, they obviously work!). When I get the spring tester, I will be testing my stock springs, the heavy Barnett's, and various thickness spacers.
icarus
posted September 10, 2008 02:57 PM
I run both Brock's springs and spacers. There was a noticeable difference in lever pull. I ride it daily in bumper to bumper traffic and do not get fatigued. At the track it helped to get the bike moving much better.
8.820 @ 161.05
Popsicle
posted July 05, 2011 08:59 PM
I put the spacers in my bike and it was to tight also. does anyone have a picture of exactly where they should be installed
Popsicle
joel787
posted July 05, 2011 09:29 PM
It aint too hard, top of the spring then hand tight, they freeking nice
CraigChrist
BAWLS
posted July 05, 2011 10:06 PM
I ran the springs and had great luck with them... I learned the hard way the spacers don't go on under the springs lol. As it turns out those posts are tapered and they don't take kindly to spacers.
60ft-------1.42
1/8th------5.97
mph-------119
01smokes
posted July 05, 2011 10:33 PM
I've never ran the spacers but I have ran heavy spring in my turbo bike and they worked good, I like the feel of stock tho and it works for me for now in my new zx14 so that's how it will stay until I need something to hold power
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
joel787
posted July 06, 2011 02:59 PM
i got heavier springs and spacers but is not as hard and grabby as i thought it would be, should i tighten the bolt more?
posted July 06, 2011 03:19 PM
all 5 spacers worked excellent for me...
0.28968191146851 seconds processing time
