BIKELAND > FORUMS > ZX-14.com > Thread: on board air compressor NEW TOPIC NEW POLL POST REPLY
jdrill04
posted September 06, 2008 11:00 AM
has anyone tried running a little compressor with the muzzy airshifter , and if so what psi do you set it at. i asked and was told it takes 120 psi to shift . but does that mean 120 psi each shift.
posted September 06, 2008 11:54 AM
you will want to have a low pressure tank so you have enough volume to make a few shifts in a row. set it at 150 psi. you can just use the high pressure tank that comes with the muzzy kit if you want, or your swingarm, or whatever you can seal and can take 150 psi.
shane661
posted September 06, 2008 12:39 PM
The problem I see with using air is that you are guaranteed moisture in the system. I'm going with CO2, and perhaps later, Nitrous.
You can use even a 9 oz. CO2 bottle and get 150+ shifts....without moisture.
madboost
posted September 06, 2008 02:53 PM
shane is right, i'm using a nitrous shifter set up another problem on the 14 is where are you going to mount the compressor, because it will not fit under a stock seat.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
jdrill04
thanks guys
posted September 06, 2008 05:22 PM
a regulated high pressure system is the way to go. i use co2, but have been told nitrous is a cleaner gas.
locally i can get a 20oz co2 tank (from a paintball gun) filled for $7. good for a few hundred shifts
but if you want to run a compressor its up to you. lots of room if you extend the bike
06redzx14
posted September 07, 2008 10:38 AM
I've got a CO2 on off valve and regulator I'll sell for $80 tyd. Went back to regular air after one track day. 9oz CO2 bottle on the left side of the tail compressor in front section under the seat
0.2423460483551 seconds processing time
