BIKELAND > FORUMS > ZX-14.com > Thread: Added a 12V Cigarette Lighter Plug to my ZX-14 (pics) NEW TOPIC NEW POLL POST REPLY
nyc zx-14
Manager Star Toyota Bayside,NY
posted August 19, 2008 06:22 PM
Bored tonight, I installed a cigarette lighter plug from a Toyota into the left side instrument cluster cover. Now I can charge my cell phone, plug in a GPS or trickle charge my battery all from convienient spot on my bike. It's fused at the battery with a 10 amp fuse.
Two views of the plug and it's location:
Here's the plug with its cover opened:
Here's the fused connection at the battery before the wires were secured and tucked away:
Currently?
2007 Kawasaki ZX-14, 1999 Kawasaki VN 750, 1976 Suzuki RE-5 Rotary
http://www.goldiesplating.com
  Ignore this member    Click here to visit NYC ZX-14's homepage.
derpie
Dont judge a book by its cover
posted August 19, 2008 06:30 PM
And that doesn't interfere with the motion of the handlebars with a plug in it ? If not that looks like a great spot and theres two of them on the front fascia.
nyc zx-14
posted August 19, 2008 06:33 PM        Edited By: nyc zx-14 on 19 Aug 2008 20:10
Socket is fairly deep and when in use, doesn't touch the bars at all. When bars are turned to FULL lock, I guess a long adaptor could hit the levers, but I don't have any long adaptors nor do I ever anticipate turning full lock when in motion.
Currently?
posted August 19, 2008 06:49 PM
nice!
derpie
posted August 19, 2008 07:33 PM
ok I'm going to look into that option I'll probably do both spots.
derpie
posted August 19, 2008 07:35 PM
Is it the same depth behind both spots? are all sockets the same depth or do they come in different sizes?
derpie
posted August 19, 2008 07:36 PM
Oh and that isn't speaker wire is it? that I see in the picture.
nyc zx-14
posted August 19, 2008 07:37 PM
Mark your drill location CAREFULLY before drilling as there are clearance issues BEHIND the panel if you are "off" with your hole.
Currently?
derpie
posted August 19, 2008 07:38 PM
looks like you centered it right.
nyc zx-14
posted August 19, 2008 07:39 PM
Not sure about either question as I didn't check the right side yet nor have I shopped for lighter plugs. I had this one laying around the shop so I put it to use. lol.
Currently?
derpie
posted August 19, 2008 07:41 PM
ok I will measure both sides but emphasis will be placed on the right. seeing how you have the left covered.
nyc zx-14
posted August 19, 2008 07:42 PM
Yeah..... but it's GOOD speaker wire. lol I'm only using it for LOW amperage applications so it will be fine. If you require higher amperage, use better wire. I was in the electronics industry for 12 years in my "younger days" and know what I can and can't "get away" with. If you have ANY doubts about your application, by all means use heavier gauge/insulated wires.
Currently?
derpie
posted August 19, 2008 07:43 PM
Or maybe i'll just use one of those y adapters well see.
nyc zx-14
posted August 19, 2008 07:45 PM
With the Y-adaptor, you will PROBABLY have handle bar lever clearance issues. (I think)
Currently?
derpie
as long as its fused i guess . its cool but those gps systems pull at least an amp charging that is. radar, cell phone. etc etc....
derpie
posted August 19, 2008 07:47 PM
should be fine the y adaptor has 6 inch leads off of it I'll wire tie it if it get out off hand.
nyc zx-14
posted August 19, 2008 07:59 PM
Plug is 10 amp fused with a 120 watt limit which requires only 14 gauge wire for an 8.5 foot run. This particular twin lead is 12 gauge and would handle up to a 13 foot run.
The distance I used is only a few feet so I could EASILY run something drawing 10 amps.
Currently?
derpie
posted August 19, 2008 08:09 PM
thanks for the info .
Nick2k
posted September 07, 2012 10:34 AM
What did you use to cut the hole? I'm about to do this project, and don't want to mangle the plastic!
Wheelie
Old Man
posted September 07, 2012 10:46 AM
maybe a paddle bit?
wee
ericwms12
Eric
posted September 08, 2012 05:46 PM
very nice. i have been thinking of doing that myself.
eric
0.27027201652527 seconds processing time
