BIKELAND > FORUMS > ZX-14.com > Thread: 2007 ZX-14 Navigation Question NEW TOPIC NEW POLL POST REPLY
rich s
posted August 19, 2008 06:32 AM
Hey guys, I just picked up my new 2007 ZX-14 Saphire Blue last night. Man, what a bike! I want to mount a Nuvi to the bars but I don't know where to tie in the wiring. I can make the mount no problem so if you can just tell me how to wire the power to it that would be great. Also, what exhaust do you recommend? Thanks in advance.
Superman T
posted August 19, 2008 07:36 AM
rich s-Welcome to the club! First, if you look on the third page of this board you'll see a service manual(from Black Magic) for your bike. On the 2nd page of that thread, you can download the entire manual. That should answer your wiring question....2nd- I recommend going with Brocks. If you purchase a system from them, you'll get top quality parts, dead on maps(no need to spend money on dyno), major performance improvement, good cometics, and awesome customer service/support. Best regards......
posted August 19, 2008 09:03 AM        Edited By: stevewfl on 19 Aug 2008 10:04
? i don't think Brocks makes navigational mounting hardware-
hi rich, I used the RAM hardware that came with my garmin ZUMO 550 that worked great. Dubious or one of the guys on here turned me onto it.
A more expensive and elaborate way is to use a techmount techmounts.com. I've always tried to avoid the stem mounts personally, but some like them. techmount now makes a mount that goes around the fork tube, not sure if that is an option for the 14, its not for a lot of bikes but check the page.
as far as where to wire, there are 12V constant places all ovbe the front of the bike, or you can go back to the battery. suggestion: fuse it if you go directly to bat.
posted August 19, 2008 09:10 AM
This is exactly what the GPS looked like on my bike, and the pics I used as an example to make it happen
"It easily clears the gauges while riding, there is absolutely no obstruction:
I am using only the lower-bolt on the control mount, the other end of the Ram mount rests on the top of the handlebar mount. It's very solid and does not move at all:
Superman T
posted August 19, 2008 09:33 AM
Steve, if you've read his ENTIRE post, he ask about exhaust systems
review
posted August 19, 2008 09:56 AM
OOPS-
my bad, apologies!
Superman T
posted August 19, 2008 10:56 AM
You're cool, no worries. The pics and info you gave should be beneficial to Rich s. Man I gotta get me navagation. Do you still have that unit for the 14?
posted August 19, 2008 12:21 PM        Edited By: stevewfl on 19 Aug 2008 13:24
Superman T, go with none other than the ZUMO 550 motorcycle GPS. It'll come with the hardware to mount to the 14 in the box, or you can go with the techmount option.
Too many options on it to list, but the fact it'll deal with 3 feet of water is my favorite so far, I've got caught in some serious tropical storms in FL and it held up much better than the bike and I!
I still have mine, and fortunately it has a 5 HOUR battery, because its "temp-mounted" to my litre-leaner :P
Superman T
posted August 19, 2008 12:38 PM
Damn, that looks sweet! Thanks for the info bud! Kinda wish you had it for sale but I see the Yamaha symbol
butta4hc
posted August 19, 2008 01:02 PM
I have the Garmin NUVI 200W (for now). I keep it in my tank bag just like he does. I also have the power supply wired back to the battery and fused. Only problem is that I have to take my eyes off the road and cover the front of the unit from the sun in order to see it. At night a quick peek down and I'm good. At some point I'm gonna break down and get the real deal. The whole set up is $800 or better!!! If someone has a better price somewhere lemme know.
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
posted August 19, 2008 01:09 PM
ya that bag mount is temporary for me too, but works great for a quick GPS fix
Amazon.com has it for $675 last I looked. I paid about 800 but that was over a year ago
posted August 19, 2008 03:12 PM
here's another mount I concocted - needed speed and distance solution on bicycle workouts and the ZUMO 550 fits the bill
Cannondale roadie:
rich s
posted August 20, 2008 04:26 AM
Thanks for the reply's guys. I will take a close look at all the info this weekend.
I have had the bike for a day and a half. I put on just under 200 miles on it. Having to keep it under 4r's sucks but it is letting me get used to the bike slowly. I am in love with this bike so far.
One more question for you guys, my hands are getting sore on the longer rides. Is there a grip that is more comfortable on the hands then stock? Thanks again!
posted August 20, 2008 07:11 AM
I can't help much with setting the bike up for comfort, but I'm sure some can. Grips swapped to foam, heavier bar ends, and someone even makes a product to raise the clip-ons in general.
07zx14blk
ZX6R, ZX9R,ZX12R,ZX14
posted August 20, 2008 07:12 AM        Edited By: 07zx14blk on 20 Aug 2008 08:13
You can try a new grip or palm-padded gloves… but what really helped for me was Bar Risers (Heli Risers), for there $ there is nothing that will make your bike more comfortable to drive on a long haul.
http://www.helibars.com/proddetail.php?prod=HC2614
rich s
posted August 20, 2008 08:14 AM
Thanks for the input. I will check out the new grips first. I do think that my body will get used to this. My last bike (FZR) was over ten years ago. Every ride is getting more comfortable though. Thanks again!
flyboy
posted August 20, 2008 09:55 AM        Edited By: flyboy on 20 Aug 2008 10:58
I created this GPS setup for NASA which is now used in all the Space Shuttles. Wireless and able to operated in a O gravity environment,
it is approved up to a 200 mile an hour impact. Designated the Z461-578, it is available to Bikeland members for only $199.99 each-- this week only.
Not available in stores or on TV, supplies are short and demand is crushing so I recommend ordering immediately.
Pick up your phone and dial 1-800 OGRAVITYGPSHOLDER. Guaranteed or your money back.. less shipping and development costs.
"The World's Fastest Indian"
One fast red ZX-14,
07zx14blk
posted August 20, 2008 10:29 AM
LOL….
Flyboy... That’s a deal at one hundredth of the price, I will take 3!
posted August 20, 2008 11:44 AM
NICE!
flyboy
posted August 20, 2008 02:19 PM        Edited By: flyboy on 20 Aug 2008 15:21
LOL….
Sorry... I sold my last 100 within 15 minutes of posting but I am now taking backorders.
Possibly you might be interested in my NASA approved relief tube for the ZX-14? Modestly hidden in your back left fairing,
this 200 mph impact approval titanium space age container can store up to 48 ounces of your precious fluid.
It is available in three different sizes. 48, 36 and 24 inches from pouch to container. The space age reinforced tubing is neatly sewed into the instep of your leathers
and is hooked and unhooked with a gold plated Space Age 0 gravity attachment at boot level to allow walking around prior to entry and upon landing.
The "man pouches" TM are made with re-enforced Space Age design wire reinforced tubing for a guaranteed snug fit. Sizes available are 12 inches for Land Speed Racers,
10 inches for Drag Strip racers and a 6 inch mini-me Space Cadet size for those that troll. Photos will soon be available--
One fast red ZX-14,
0.24724197387695 seconds processing time
