BIKELAND > FORUMS > ZX-14.com > Thread: very unhappy NEW TOPIC NEW POLL POST REPLY
specialzx14
posted August 18, 2008 06:30 PM
very unhappy
hey people tell me what the problem is. i have a 07 14 flies out,drop in map (thats been richened) m4 slip ons, stretched 7, and a 40 shot geared 16/43. i have left at all rpm's best 60ft has been high 1.40's low 1.50's. but i always run a 6.30. its like the bike dies after 60ft. is it because it has not been tuned or what i dont understand! i think the bike is too heavy i wish i would have bought a 1000 the 14 seems weak to me now.
jessejames82
posted August 18, 2008 07:05 PM        Edited By: jessejames82 on 18 Aug 2008 20:07
...maybe not riding it right ... maybe maybe maybe .... call me crazy i went 1.40 60 ft w/ a 5.54 on 50 dry at 134 ... at 5'' over ... the extra weight of the bike didnt hurt it .. i would like to see a stock motored 1000 do that
Orient Express Rider
SuperSport ZX 14
6.000 8th mile
01smokes
posted August 18, 2008 07:09 PM
what elevation is your track at that will kill ET and MPH if you have bad air
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
specialzx14
posted August 18, 2008 07:11 PM
what do you think it is then how can you not be ridin it right when your tryin to twist the grip off do u think tuning it will drop the time or what i dont understand
specialzx14
posted August 18, 2008 07:14 PM
hell i have no idea im in north alabama i do know there are 1000's and busas runnin low 6's and high 5's im bout tired of sinkin money in this thing wish i could sell it but i will never get what i need to pay it off
Bently
2012 14r In Blue and no Mods!
posted August 18, 2008 07:21 PM
What's your weight? Is the bike Bogging? With those 60 fts you should be running 5.90's to 6.0's. I'm 216 in shorts and ran 5.86 on my 14 with no NOS with a 1.45 60 ft. But then again I had Brock System and map.
specialzx14
posted August 18, 2008 07:23 PM
i weigh 185, no bogging, bike just seems slow to me compared to others ran a 6.17 one time have not been able to get close since
smokinzx14
posted August 18, 2008 07:26 PM
First get rid of them crappy slip ons and crappy map ... I bet money a stock zx14 makes the same hp as your does now ..
Second you need more seat time .
Third you think you are slow now ? go ahead and get a 1000 and you will be real slow ... A new Busa with the mods you have now you would still be slow ...
Now go Order a Brocks Smeg and race map and get some seat time ...
specialzx14
posted August 18, 2008 07:28 PM
hey i hear u been giving my buddy some advice u know he out weighs me by like 60 lbs. and still out runs me thats sad jdzx14
BlackMagic14
posted August 18, 2008 08:13 PM
Get a full system and a descent tune in the bike. IF your sixty's and 330 are there and the bike isnt running the time then you need to adjust the things that are making the power i.e. the pipe and tune, it isnt the bike itself we have seen over and over again the the 14 is a proven platform and with the right equipment and rider it will provide the results you are looking for... Oh yeah SEAT TIME SEAT TIM AND MORE SEAT TIME
lietoome
posted August 18, 2008 08:16 PM
Are you venting, or asking for advice? If you're venting, try having No local track, or unable to ride for a year. Thank God there's a new local track I can use next summer!
If its advice you need, add some more info:
1. Drop in map? That alone can be 90% of your problem. 40 Shot with a 'richened' map?
2. Like smokin' said, dump the slip-ons & more seat time.
3. What are you doing diifferent between now an your 6.17 run?
4. Is the bike strapped and lowered?
5. Document everything you do to your bike. suspension settings, times, temp, humidity, tire pressure,etc. Race against your own best time, not 'everyone else' at the track. If you study up on what you're doing wrong, you can fix it one step at a time.
6. Is the tire breaking loose at mid-track? Launch?
7. Extended swingarms don't do shit for you if your suspension is not set correctly, they will actually hurt your times if not dialed in.
8. What kind of tires? Pressure?
9. Is it a well prepped track? Or do you have to pick small line for traction?
10. You may be over-geared...
11. Is your NOS set up correctly?
12. Swap bikes with someone else, see if they can provide feedback for whats possibly wrong---this could also prove that its you and not the bike.
13. I think if you take an honest assessment of the bike, you will see where the flaws are that are hurting your times. I usually make two runs, park the bike, take notes, make adjustments and then 2 more runs, maybe 3 to see if I can get consistent results. My problem is usually my consistency, not the bikes.
14. Elevation?
***Didn't add any of these comments as an insult, but I've learned just as much reading/listening as I have at any track day on my own.
The more info you can give, the better chances that someone can help....works for me anyway. Best of Luck.
ninja12
posted August 18, 2008 08:22 PM
What RPM do you go to second gear?
The 1-2 shift is the most important .
short shift second and you just wasted your good 60'.
When do you pick your feet up.
Air or foot shifter.
You better be very light if you think you are going to go faster on a 1000.
zx14mike
posted August 18, 2008 11:10 PM
Good points Jeff, track/bike prep and consistency is what i need to work on when i get back to the track.
lietoome
posted August 19, 2008 12:30 AM
There are just too many variables when dealing with fuel maps, this is exactly why I chose Brock's SMEG, the map support alone was worth $300 to me.
I can't fathom adding NOS to the mix....I'd be hella lost.
Bently
posted August 19, 2008 03:09 AM
What's your mph?
madboost
posted August 19, 2008 05:05 AM
i weight same as you unsuited and i've been 6.0 with stock w/b just pipe and tune.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
SteddyTeddy
posted August 19, 2008 06:45 AM
Must be your tune or you just need more seat time. I run 6.10's on my ZRX12 with 155hp SAE. First time Smokin let me ride his 14 I pulled a 6.20 leaving very easy.
Superman T
posted August 19, 2008 06:48 AM
specialzx14- I know you've heard this in the above responces, please lose the slip-ons!!! All of the members that have purchases slip-ons have stated, no inhance performance but they liked the look of dual exhaust. By the sound of your thread you want performance and cosmetics is secondary, change to a full exhaust 4-1. I'm partial to Brock due to the most HP/torque out of all manufacturers(IMHO). I can personally convest to the performance gains. If you look in the Classified section on this board, I'm sure you can pick one up used if you want to shave some cost. Give your 14 a fighting chance before you get too sour about it, good luck
smokehouse4444
XX to ZX
posted August 19, 2008 09:53 AM
I was the same way. I was going to buy some Two Brothers slipons for the sound and I liked the looks better. After getting an earful from members on this site, and from dynoing and talking with Johnny Cheese, I am definitely going to get the Brocks full smeg system. Like I've been told, if you are going to spend the money, might as well get the performance. I AM definitely looking, so if anyone on here knows of a system for sale, please let me know. Good luck specialzx-14!
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
MJ
posted August 20, 2008 02:07 AM
Like everybody else has said get that dog tuned right. I bet you turn that hush-puppy into a pit-bull
jdzx14
posted August 20, 2008 04:38 AM
Well see, i dont outrun him every time, its back and forth, i am kinda frustrated too, but alot of mine is my weight , i proly weigh 260lb with leathers, but the best i can get is a 6.23 on motor, but i have a few more parts than he does so i am gonna try the brocks exhaust and a good tune and if that doesnt do it, i guess i will just keep thorwing money at it.
2007 Black ZX-14
Sticks_n_Stones
posted August 20, 2008 12:21 PM
Going from a Muzzy 4into1 to a Brocks sounds like one big waste of money to me. The extra 5-8 hp gain (IF your Muzzy isn't a M10/M14 combo which makes same or more power than Brocks Smeg) is not worth the $1,000 spent!! Better off spending that money on a custom PCIII map and seat time at the local track with an earful of advice from the fast guys at the track.
Don't pantsy ass it when it comes to asking advice, or asking a skilled rider to ride your bike. Even if it's a 'Busa or literbike rider, most of them would be more than glad to help!
And I've never known a racer to turn down a chance to ride a competing manufacturers bike, or offer up advice on things he see's you doing wrong. And if he runs your bike, you can be assured he'll take it to its limit because he most likely is as interested in the results as you are! Boys are always looking for better toys
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
wrenchhead
posted August 20, 2008 12:27 PM
if you looking for a cheap good, not the best, but damn good for the money check out Yoshimura's website, they have a TRC full SS, Titanium system on sale....just got mine $490 shipped to my door! Looks like a nice piece, we will see next week after i get my power commander how it performs!
madboost
posted August 20, 2008 12:45 PM
couldnt tell you about yoush stuff but heres a quote from a local "tuner" about two brothers
"They suck, customer came in for a custom map. 2008 ZX-14 we normally get 175-178 piped and tuned with pump gas & 180-183 with race fuel depending on the pipe and fuel.
Two Brothers full system: 166 HP almost less than stock he spent almost 1K....save your money. Another example of bent tubes and no R&D."
9.44@144 w 1.5060ft
Sticks_n_Stones
posted August 20, 2008 01:53 PM
I don't buy that BS about Two Brothers. I put there slip-ons on and imediately noticed a seat of the pants difference. I couldnt bring the front tire up with a rollon power wheelie in second gear before, after it I could do it every time! I guesstimated about a 8-10 hp diff, all at top end. Couldn't compare it to my full M10/M14 Muzzy though, did too many mods at once.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
0.274080991745 seconds processing time
