BIKELAND > FORUMS > ZX-14.com > Thread: wheel freespin? NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted August 18, 2008 07:42 AM
wheel freespin?
How much free spin should a wheel have? When I spin my wheel I can barely get it to do a full revolution. This is the same on both the front and rear tires. Is this normal?
Loud pipes and bright lights save lives.
BobC
posted August 18, 2008 07:49 AM        Edited By: BobC on 18 Aug 2008 08:52
Exactly why some sprinters use O'ring-less chain, ceramic bearings and remove a front caliper.
Less than one revolution sounds a bit suspicious though. Best you can do without the above is to make sure the brake pistons are retracting properly so the pads aren't causing drag and keep the chain adjusted and lubricated.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
wheelie
Old Man
posted August 18, 2008 08:50 AM
remove the calipers and spin the wheels?
wee
zx6reaker
posted August 18, 2008 09:21 AM
Alright, removed the calipers and spins a lot better. Not freely but definately much better. Can you adjust the brakes or check them somehow?
Superman T
posted August 18, 2008 12:14 PM
Your braking system is working fine. The brake pads needs to be close to the rotor to stop you from hitting a foolish person in a car. Would you rather lose the braking in order to ride faster(more rotations)? If you could'nt stop, then I would recommend servicing. Just think about the braking system on a car....same concept...
posted August 18, 2008 12:45 PM
front wheels on a car will spin more free if you remove the brakes too, something about the force/resistance of rotating mass may be coming into play
brakes. who needs 'em anyway
Superman T
posted August 18, 2008 01:11 PM
Steve-LMFAO, man that's some funny stuff.... that was a good 2 minute laugh....LOL 4 real
BobC
posted August 18, 2008 01:14 PM        Edited By: BobC on 18 Aug 2008 14:33
Yes to the above but the pistons and their seals can become contaminated and then they can stick preventing the pads from releasing the disc when the hydraulic pressure is removed. They do require checking and some maintenance occasionally.
You can remove the caliper and gently apply the brake to make sure both (or all) the pistons move out, just a little or they will pop right out. While you have them moved out make sure there is no build-up of dirt around them and then make sure they retract again with gentle pressure. High mileage bikes and especially one's that have been through a wet or snowy winter or two often have sticking brake pistons which continue to grip after braking. Usually cured with new seals.
Stock wheelbase
0.26805210113525 seconds processing time
