hardatit
posted August 01, 2008 02:29 PM
ZX 14 kick stand
Is the kick stand on the 14 made of cast? Thinking of cutting and welding, but if cast It's harder to weld.
Juan ZX1400
posted August 01, 2008 02:39 PM
I ded it and its good to go
DC
posted August 03, 2008 07:04 PM
I cut and welded two of mine and it's not that hard to weld. If you're going to paint it anyway, you can weld it with a stainless steel rod using the arc process. I cut mine way down low and placed my bike on a board to make sure I had the right angle. Came out perfect, can't tell the difference once you repainted it. I used a 3/32nd rod.
