BIKELAND > FORUMS > ZX-14.com > Thread: Nitrogen filled tyres NEW TOPIC NEW POLL POST REPLY
weaver
posted July 23, 2008 10:04 PM
I went to the tyre shop to check pressures recently and the guy recommended I use nitrogen rather than air. Benefits are said to include less leakage and cooler running (which may or may not be a benefit). has anyone any experience or knowledge of this?
BobC
posted July 23, 2008 11:50 PM        Edited By: BobC on 24 Jul 2008 03:07
Better pressure retention.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
ninjaboy311
posted July 24, 2008 07:35 AM
I use Nitrogen. Doesn't swell like air does when you do a burnout, so pressure remains 'near' constant. Its dryer than air, which is why I use it for my air shifter too.
jerchung
posted July 24, 2008 09:24 AM
I am also curious about the nitrogen. Is the ride smoother?. What about cornerning?. What are the pro's and con's?.
ghostman
posted July 24, 2008 10:01 AM        Edited By: ghostman on 24 Jul 2008 11:01
On top of that; where can you get this stuff?
I'm There Whether You See Me Or Not.
posted July 24, 2008 10:09 AM
I've been using nitrogen for a couple seasons Drag Racing now...
I get the Nitrogen air from my local COSTCO wholesale tire shop...They are more than happy to fill up my air tank!!!
I use it in the front and rear...The air pressure is very consistant, predictable and never loses air !!!...Once you see how the air reacts to how you ride, it performs the same every time you use it...
Hope that helps!!!
weaver
posted July 24, 2008 12:45 PM
Thanks for your comments - I'll give it a good road test when the weather warms up - winter here.
0.41461205482483 seconds processing time
