BIKELAND > FORUMS > ZX-14.com > Thread: race stands? NEW TOPIC NEW POLL POST REPLY
tater
Shakin off the Haters
posted July 22, 2008 08:40 AM
race stands?
will they work with swing arm extensions. Or do i have to weld a piece of alumium to the extensions , they tap it out and bolt the spoils on. i Just need a professional opinon.
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
FastestBusaAround
I eat Fish...
posted July 22, 2008 09:14 AM        Edited By: FastestBusaAround on 22 Jul 2008 10:15
I use a steel rod through the rear axle and just lift from there instead of the spools, which I don't have on my Trac swingarm either. Works like a charm!
FYYFF!!!
shane661
posted July 22, 2008 09:49 AM
The spools won't work with extensions. You can use a stand, like a pitbull or lockhart, that doesn't require spools.
While you could put something through the axle, it wouldn't allow you to remove the wheel assembly.
FastestBusaAround
I eat Fish...
posted July 22, 2008 03:31 PM
True -- but I only needed it to grease the chain...
FYYFF!!!
tater
posted July 23, 2008 08:26 AM
thanks a million guys . its just a pain in the ass to clean and lube the cain on the ground
ZX-14 06
Flies out
-1 front, +2 rear
Tiger tail
64inch wheel base
lowering links
0.27198600769043 seconds processing time
