BIKELAND > FORUMS > ZX-14.com > Thread: Mounting Power Commander under 08 seat? NEW TOPIC NEW POLL POST REPLY
kawabonzai
Leader of the Back.
posted July 15, 2008 01:37 PM
Yo1
I was posting on another topic about this issue, thought I'd run it by you guys.
I want to mount my PC-III under the seat, but the plugs are huge and will not route from the seat section to the injector connector. I hate that thing on my left Ram tube.
anyone mounted their PC-III under the seat? If so please provide detailed instructions.
Thx,
-B
2009 ZX-14 Candy Lime Green
3boysand3bikes
posted July 15, 2008 07:44 PM
Bill the painter from New York.... mounted his under the seat. I believe that he ran it through the frame on the right side under the tank. You would have to call him. He used to be a sponsor but I have not heard from him. I asked him about it before I got my PC3 and he said it was really tight and not easy.. but it worked perfect. I believe there were quite a few that did it... but he is the only one that I was able to talk to about it. I will search to see if I find him... (Needless to say.. it CAN be done... )
ninja12
posted July 15, 2008 09:51 PM
It worked on the 06.
it's a tight fit, take your time.
ZXLNT
posted July 15, 2008 10:07 PM
The plugs will fit. I think I had to take off a bracket to get to slide by, but you can mount it under the seat..
Smooth_G
posted July 15, 2008 10:11 PM
it will go ,,takes a little work,,,i routed mine through with a clothes hanger wire
kawabonzai
Leader of the Back.
posted July 15, 2008 10:43 PM
Hmmm, is there some frame guard that comes off on the left side?
I only see the slot inside the frame where the big bundle of wires go thru.
Thx
zxbob
posted July 16, 2008 04:14 AM
It can be done .... just take your time !
Bob
AZ ZX14
posted July 16, 2008 04:59 AM
I'm just curious why you want it under the seat. My thought was by mounting it to the air tube by velcro, it would be less suseptable to shock.
I also wanted mine mounted under the seat but opted to just run an extended USB cable to that area. Now I just pop the seat and connect it to the laptop or dyno.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
0.23753595352173 seconds processing time
