BIKELAND > FORUMS > ZX-14.com > Thread: Extended swingarm - chain hitting NEW TOPIC NEW POLL POST REPLY
Shogun
posted July 15, 2008 12:30 PM
Dumb question, but before I go crazy trying things...I've changed to a 6" over extended swingarm, lowered front, lowered rear (middle hole) with an EK ZZZ chain. Still using stock gearing for now.
Chain tension appears correct but it hits against the swingarm on small road bumps at low speeds. Is this typical on extended bikes or do I need stiffer springs, extra tight chain, etc?
Thanks in advance for your input.
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
ninjaboy311
posted July 15, 2008 12:42 PM
This is typical. Don't panic and over tighten your chain. Some custom swingarms come with chain roller wheels to prevent chain slapping as seen here on mine.....
0.32450103759766 seconds processing time
