BIKELAND > FORUMS > ZX-14.com > Thread: engine temp overview NEW TOPIC NEW POLL POST REPLY
Smooth_G
posted July 13, 2008 11:40 PM
when i first got this bike it ran hot,,i read of other people on here who said the same thing, but they all had less then a thousand miles ,,i put a brock ceramic pipe on n a p/c,,that helped alittle,,i put water wetter n engine ice in the cooling system n that helped a little,,i even added a second fan,,THE PROBLEM WITH THIS BIKE WAS,,THERE WAS NO PROBLEM,,THE ENGINE WAS TIGHT,,N THE EXTRA FRICTION MADE IT HEAT UP,,NOW IT HAS 5500 MILES,,N RUNS REAL COOL,, i believe it takes 5000 miles to loosen this bike up right,,it was hard to shift,,hit false neutrals into 6th,,,now it shifts cherry,no false neutrals,, it was 114 here a couple days ago,,i was going through traffic when the first fan turns on,,i hit the second fan switch,,it never goes over 1 block above the middle with 2 fans,,,with 1 fan it will go 2blocks above the middle sometimes,,,,sometimes the first fan will turn off while using the second fan,,this tells me that 2 fans helped alot
posted July 14, 2008 12:45 AM
You are correct in your obserations!
My bike losened up and shifted much better with time....
dcjens
Wet side of Washington
posted July 14, 2008 05:11 AM
I'd like to know more about adding a second fan...How'd you do that?
Black 06
BobC
posted July 14, 2008 08:09 AM
I fitted a Tiforce system and PC3 at under 1000 miles, the running hot problem went away at that time and I assumed it was caused by the standard exhaust system.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.21712398529053 seconds processing time
