BIKELAND > FORUMS > ZX-14.com > Thread: Extra fuel added (pics) NEW TOPIC NEW POLL POST REPLY
Northmedic
posted June 22, 2008 07:49 PM
Got this jr fuel can system modified and added on to bike for my holiday next week its over 300 km between gas stations
I,ll be right back
ZXLNT
posted June 22, 2008 09:00 PM
Doesn't look too safe.
200hp_zx14
posted June 22, 2008 09:07 PM
Your bike should easily be able to handle 300km distances if you ride normally. I figure if I rode a normal 75mph, I could probably get at least 200 miles out of the tank. But however you choose to mount the external tank is up to you. As long as it stays attached, and is not in your way, its all good.
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
butta4hc
posted June 22, 2008 09:22 PM
I read an article somewhere on how a guy modified his tank on a GSX-R 1000 (I believe) to get more fuel capacity. Something to do with a battery relocation and such. Don't quote me on it. you might have to google it. That extra cell is nice if it is gonna be a temp solution to your problem but if you are really in that bad of a spot maybe you should do some research and see about upgrading your fuel capacity. When I see that red can I thinkg about things like heat or a pssible low side and sliding ON THAT SIDE and you engulfed in flames shortly afterwards. Maybe you should look into fabricating something that mounts high and to the rear almost like a a hard tail bag would? In any event, good luck with your experiment.
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
butta4hc
posted June 22, 2008 09:32 PM
Hell! Did a little research myself and came across this:
http://www.tourtank.com/
It may obviously work better on crusiers but If you are crafty enough I'm sure it can be applied to sportbikes as well.
Butta
Hot Commodities MC
Paterson, NJ
road rage
posted June 22, 2008 09:34 PM
Just get 2 or 3 of these and be done with it.
http://www.msrgear.com/stoves/fuelbottle.asp
Phil
northmedic
posted June 22, 2008 09:40 PM
I went with this sytem as it was designed for Atv and Off road applications the bracket that came with it is 1/4 plate drilled some holes couple of spacers and it bolts to the rear foot peg mounting holes , this can is the same material my acerbis tank is on my race bike XR650 . it does not impead my legs it sits further back then a passengers foot almost , as for 200 hp my bike stock only got 220 km max fro distance , My VN 2000 just gets 300 kms if i am lucky , some other forums i have chatted with some guys and they use pop bottles in back packs with gas in them thats a no way thanks , i have thought about a small custom aluminum tank where the passenger seat is for future , besides it s just a function thing .
I,ll be right back
northmedic
posted June 22, 2008 09:43 PM        Edited By: northmedic on 22 Jun 2008 22:48
will certainly look at this maybe get a spare stock seat from e-bay cut and mount it in the passenger seat spot
I,ll be right back
butta4hc
posted June 22, 2008 09:50 PM
That's a plan. If I were in this same predicament I would probably go this route before anything else.
Butta
Hot Commodities MC
Paterson, NJ
northmedic
posted June 22, 2008 10:03 PM
this the mounting bracket for the hell of it
I,ll be right back
0.25042700767517 seconds processing time
