BIKELAND > FORUMS > ZX-14.com > Thread: warranty ? NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted June 19, 2008 05:44 PM
warranty ?
What all can you do to the bike if it is still under warranty and not void it? I'm thinking of the pcIII and pipes, but don't want to void my warranty. Thanks
Loud pipes and bright lights save lives.
Peno
Peno
posted June 19, 2008 06:17 PM
warranty
As far as I know Engine Internals Turbo NOS Flies Out but U can put back in all void
zx6reaker
posted June 19, 2008 06:38 PM
Not quite sure I understand what you're saying. As long as I can put it back to stock it's o.k.?
derpie
Dont judge a book by its cover
posted June 19, 2008 08:18 PM
exactly what he means.
man00
posted June 19, 2008 09:14 PM
Any change to the stock bike some think Kawi has to prove.. that change/mod was the reason for warranty needed. I seen work both ways it really depends more on the dealer if he will work with you or not. Good example is no 2nd gear or jumping out of gear..Kawi and almost all will say owner abuse.
Smooth_G
posted June 19, 2008 10:27 PM
from my experience it all depends on the relationship u have with your dealer,,i am getting my yamaha fjr1300 fixed under warranty slipping out of second gear,,it has aftermarket pipes,p/c 3,,syn oil,,,n he knows it,,n is covering it,,,,
4TEEEN
posted June 20, 2008 07:05 AM
I have spoken to Kawasaki in the past and they require the bike to be returned to stock. If you install pipes and PCIII the best bet is to remove PCIII and install the stock pipes before you take the bike to the Dealership. Most times when performing warranty work , Kawasaki sends someone out to take pictures.
I speak from experience.
4TEEEN
zx6reaker
posted June 21, 2008 08:02 AM
Just got off the phone with Kawasaki Co. and said that I do whatever I want to the bike but if something happens to it, and it was deamed the reason for failure then they wouldn't cover it. So...pipes are on the way.
lowcel
Happy on 2 wheels.
posted June 21, 2008 10:37 AM        Edited By: lowcel on 21 Jun 2008 11:38
That is illegal. Unless it can be proven that your upgrades were the cause of the problem they can't do anything about it. You can upgrade pretty much anything you want, if your upgrades aren't the cause of the problem they you are fine.
2007 Z14 SE - Yoshimura TRC full race exhaust w/ carbon can - PCiii w/ map from HPC - Flies removed - Pipercross air filter - Speedohealer - Puig Double Bubble - Fender Eliminator - GPR Steering Damper - Puig Frame Sliders - HID's - Halo's
0.26615309715271 seconds processing time
