BIKELAND > FORUMS > ZX-14.com > Thread: Engine Vacuum Synchronization ? NEW TOPIC NEW POLL POST REPLY
ShadyD
posted June 17, 2008 07:33 PM
I'm almost at 18,00 miles on my 06 and it's time to sync the throttle bodies.
Went up to Suches Ga. the first time this year a couple of weeks ago and had alot of vibration on my throttle hand.
The Twinnmax seems the way to go for this procedure. Anybody used this gauge before ?
The Kawasaki manual recomends the use of a Pilot Screw Adjuster. Is this tool really needed ?
I saw one on one of the Motion Pron web site.
kawabunga
Cogswell Cogs Installed
posted June 18, 2008 04:32 PM
The pilot screw adjusteer gives you the 90 degree bend you need to get to the sync screws. I use a Vaccumate.
ShadyD
posted June 18, 2008 06:49 PM
Thanks, kawabunga
That's the help that I needed !
davidmill
posted June 18, 2008 06:58 PM
http://forum.concours.org/index.php?PHPSESSID=b9rir0kesc0590pr5n1gipesn4&board=14.0 do a search on this site on tb sync. it isn't as easy as it should be . good luck
davidmill
posted June 18, 2008 07:02 PM
http://forum.concours.org/ try this
0.28881502151489 seconds processing time
