BIKELAND > FORUMS > ZX-14.com > Thread: 16 Tooth Sproket NEW TOPIC NEW POLL POST REPLY
Hurricane
posted June 16, 2008 11:50 AM
16 Tooth Sproket
Just put on a 16 tooth, now its sounds like a semi truck on the highway. When throttling down it gets worse. Is this something I have to live with?
Sticks_n_Stones
posted June 16, 2008 11:52 AM
Sounds like you got a sprocket for a different sized chain. I've heard bikes that had a 520 sprocket with a 530 chain and it sounded like that, really loud. Better double check it! It'll toast your chain and rear sprocket really quick!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
zx14mike
posted June 16, 2008 02:13 PM
The 16 tooth doesnt have a rubber damper like the OEM 17 tooth does so it will make more noise and vibrate a little more particularly when new............if it bothers you that much you could always buy a new chain and put the stock 17 tooth back on and get a 44 or 45 tooth for the rear.......that is if you really like the ratio but dont like the noise or vibration
Hurricane
posted June 16, 2008 02:56 PM
Thanks, I will give it some time to wear in. I will go to 17/44 if it keeps up. Great Idea!
0.33142995834351 seconds processing time
