BIKELAND > FORUMS > ZX-14.com > Thread: 30lb loss or 10hp gain NEW TOPIC NEW POLL POST REPLY
duncan
posted June 09, 2008 05:27 PM
In the 1/4 mile if you took the same bike, rider, track, temp, etc., which would be quicker?
1. shave 30lbs off the bike
or
2. add 10hp to the rear wheel
Wheelie
Old Man
posted June 09, 2008 05:29 PM
I would say number 2. is this a trick question?
wee
posted June 09, 2008 05:35 PM
c) "john denver"
smokinzx14
posted June 09, 2008 05:37 PM
10 hp is worth about a tenth of a second and 1 mph on my bike .... I have put on 15 pounds over the last year and lost about a tenth of a second .... So if i had to guess a 30 pound weight loss would be the winner ..
posted June 09, 2008 05:38 PM
30 pounds off the rider!
fifth
The Magnificent Bastard
posted June 09, 2008 05:56 PM
just call me radio......
BOTH
kawabunga
Cogswell Cogs Installed
posted June 09, 2008 06:23 PM
Less weight requires less torque to get the mass moving and less weight requires less horsepower to keep the mass moving. So all things being equal with the same HP & torque, less weight means quicker times and higher mph.
bulldogprostock
posted June 09, 2008 06:37 PM
Lets look at the math: Bike and Rider weigh 750 lbs and the bike makes 150 hp.
Lose 30 lbs:
720 lbs bike/rider/etc. divided by 150 hp = 4.80 pounds per 1 horsepower.
Gain 10 HP:
750 lbs bike/rider/etc. divided by 160 hp = 4.68 pounds per 1 horsepower.
Give me the 10 horse's or better yet do both.
Lose 30 lbs and gain 10 hp:
720 lbs bike/rider/etc. divided by 160 hp = 4.50 pounds per 1 horsepower.
2001 Busa, 2008 ZX14R, K6 GSX1000R
Halvefast
posted June 09, 2008 07:02 PM
If you shave 30 lbs off the rider, you get much better results than off the bike.
Due to the fact you will lower the CG of the total package which will net much better ET's & Mph.
Ask anyone who has tried a drag seat if they noticed any difference,
exactly why Kawabunga's bike should ET pretty well into the 8's once they
get the set-up down and get to a good track.
ECTA Ohio Mile 195.132mph
kawabunga
posted June 09, 2008 07:07 PM
Acceleration is related to the power / weight ratio. Real numbers are as follows based on the above estimated weights and hp. The higher the calculated value, the faster it will accelerate. Not a lot of difference in 30lbs lost to 10hp gained.
150 HP
750 LBS w/ rider = .2 SUCKING HIND TIT
150 HP
720 LBS w/ rider = .208333 3RD PLACE BY A SPLIT HAIR
160 HP
750 LBS w/rider = .213333 2ND PLACE BY A SPLIT HAIR
160 HP
720 LBS w/rider = .22222 THE WINNER ( GAINED 10HP & LOST 30 LBS )
kawasaki_1965
Bone Stocker
posted June 09, 2008 08:26 PM        Edited By: kawasaki_1965 on 9 Jun 2008 21:28
Power to weight ratio is a big factor in faster acceleration.
Comparo factor: F-16 = single engine / F-15 dual engines-has more HP than the F16 ** F16 outperforms the F-15 by a significant margin due to the "power to weight ratio".
BlackMagic14
posted June 09, 2008 08:51 PM
30 pounds. when I went on a diet I noticed a much bigger difference in ET not only that but I also notice a HUGE!!! difference when I put a skinny focker on my bike
duncan
posted June 10, 2008 04:23 AM
Interesting...I would have thought the 30lb loss would have netted a winner in ET but a loser in MPH. But my question was which one is quicker so?????????????
flatoutbu
posted June 10, 2008 05:18 AM
Hmmm...well lets see. I weighed 230 in shorts last year with a best of 9.23 at 148. This year i weigh 175-180 in shorts and seen a best of 9.12 at 150. My 60's last year was alot better with 1.41-1.42, i havent had much practice this year with 60's in the 1.44-1.46 range. I think with some 60's as good or better (should) than last year i should see 9.0's....so i would guess 30 pounds is a tenth and 1 mph? Also that 9.23 was under best conditions and the .12 was not...so i might have a 8.90 in me.
06 Blue 14
9.008 at 153mph @ 195 suited
flatoutbu
posted June 10, 2008 05:28 AM
I guess it all depends on your set-up...you can drop 30 pounds off the bike just by ditching the exhaust and putting on a drag seat.
06 Blue 14
Halvefast
posted June 10, 2008 05:45 AM
OK I was wrong, I just ran the numbers thru the online dyno, here is what I got:
750lbs/ 150hp = 9.96et/ 136.8mph
720lbs/ 150hp = 9.82et/ 138.71mph
750lbs/ 160hp = 9.74et/ 139.8mph
BUT
720lbs/ 160hp =9.61et/ 141.7mph
(Source) http://www.amadragbike.com/Horsepower.asp
Hope this helps!
posted June 10, 2008 06:05 AM
Dropping the weight is cheaper than adding 10hp, depending on where the 10hp is coming from...If you have a stock bike and put an aftermarket pipe on then its all good, your getting the best of both!!!...If you already have a pipe and want to do motor work, forget it, it's way cheaper to drop 30lbs. for you and you'll physically feel better!!!
flatoutbu
posted June 10, 2008 08:59 AM
I agree with that....if it takes motor work for another 10 hp your better off dropping the weight.
06 Blue 14
Superman T
posted June 10, 2008 09:24 AM
great point!
Sticks_n_Stones
posted June 10, 2008 10:42 AM
What if I like being fat and got money to burn??
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
bulldogprostock
posted June 10, 2008 04:00 PM
Buy a Busa it'll match you ass!
posted June 10, 2008 04:02 PM
Thanks for the link halvefast....
although I don't think I'll ever acheive the results it gave me!
680 lbs, 450HP = 6.684 ET @ 203 MPH LOL
ninja14
posted June 10, 2008 07:10 PM
Lee could do it...if he were not a fat bastard now............he must be up to 130
I'd like like it as 15lbs off the rider and another 15lbs off the wheels/tires.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
Y2KZX12R
CompetitionCNC.com
posted June 11, 2008 02:03 AM
As far as 1/4 mile times and acceleration, 7 lbs = approx. 1 hp.
Loosing 30 lbs is like gaining 4.3 hp
And gaining 10 hp is like loosing 70 lbs
Y2KZX12R
CompetitionCNC.com
flatoutbu
posted June 11, 2008 05:11 AM
680 suited 9.12@149=177hp? hmm... my bike made 190 hp on Schnitz dyno which would be a 8.91@152 That sounds that better too me..
06 Blue 14
0.25316500663757 seconds processing time
