BIKELAND > FORUMS > ZX-14.com > Thread: headlights NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted June 07, 2008 11:07 AM
headlights
I wanted to know if any of you have experimented with headlights. First off my lights seemed to be adjusted really low so I checked in accordance with the owners manual. It was about 8" low at 15' away from the wall. That was way to low, so I adjusted it to what the O.M. stated and I can see much better now.
I would also like some brighter lights and I don't know what is the best to look for. Does anyone have any suggestions? I am even looking at H.I.D. lights. Thanks.
Loud pipes and bright lights save lives.
Smooth_G
posted June 07, 2008 11:37 AM
i have the same problem,,easy to adjust,,i think its cause i weigh 220 n the bike was set up for someone 160,,i want to get stronger fork springs
zx6reaker
posted June 07, 2008 05:46 PM
I weigh 190 and the hieght of the lights only dropped about an inch when I sat on it. Only took 5min to adjust though.
Why would you change springs and not just stiffen the compression?
kikonzx14
Novice
posted June 08, 2008 05:37 AM
Any chance for you guys to explain a bit about the "How to" adjusting process? Knowing the do's and don't's might save us simple mortals a lot of head aches when doing it.
Thanks in advance.
Best Regards,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
Superman T
posted June 09, 2008 07:56 AM
There's a lot of info on this forum regarding this, Just search HID. To give you a prelude to what you will read, the light housing that the 14 has does not emmit the light correctly when using a true HID conversion kits. I have found lights from the high beams from HOEN(H9) and I just purchased low beams(H11) off of Ebay but these lights aren't a true HID conversion but a xeon bulb that emitts 63k light frequency(still using the same light housing/connector). I will put them in my bike this weekend so look for some pics soon.
0.25173211097717 seconds processing time
