BIKELAND > FORUMS > ZX-14.com > Thread: Dino (Conventional) oil? NEW TOPIC NEW POLL POST REPLY
mcmmotorsports
Resident Mental Patient
posted June 06, 2008 08:32 AM
I've searched and searched to no avail. I already know that I am switching to Mobil 1 Full Syn at around 1,500 miles, but need to do my first oil change this weekend. My searches have pulled up oil filter info, but no oil info. What is a good 10w-40 Conventional oil (Not Syn) to use for the next 1,000 miles?
  Ignore this member    Click here to visit mcmmotorsports's homepage.
posted June 06, 2008 10:24 AM
Shell Rotella (minus the "T" for synthetic)
mcmmotorsports
posted June 06, 2008 10:26 AM
Interesting
davej
posted June 06, 2008 10:31 AM
I have used Kawi 10-40 for 16000 miles with no problems, 5800 miles with turbo at 5lbs.
Triumph guy
fastest-14
Fastest -14
posted June 06, 2008 11:02 AM
I would just go with the stock oil, Kawi 10W40.
butterthegreat
posted June 06, 2008 12:19 PM
+1....that's what I did....
gms118
posted June 06, 2008 12:27 PM
using moble 1 full syn car oil. not a problem. been using for 1 year, and goes to the track every weekend!
  Ignore this member    Click here to send gms118 an AIM message.
mcmmotorsports
posted June 06, 2008 12:29 PM
This I know, but I just need to know what to use until I hit 1,500 miles to go full syn. Unless you are saying you went full syn since new and have been for a year.
posted June 06, 2008 01:00 PM
we were long overdue for another oil thread
mcmmotorsports
posted June 06, 2008 01:03 PM
Is this sarcasm?
davej
posted June 06, 2008 01:56 PM
My Triumph is the bitch that gets to try all the wonder oils. 0-30 was a disaster, had to remove it after only 10 miles, 50W went through clutches and rings, 20-50 a little bit better life but not much. Mobile 10-40 motorcycle 4T racing worked wonders, no valve movement, no clutch problems, no metal filings, no engine noise. 20-50 car oil toasted the new Barnett clutch, and broke rings on the left bank. If it doesn't say motorcycle oil it ain't, noway, belongs in a motorcycle cause it don't have the critical additives for the clutch and tranny. I think I'll try Wesson cooking oil next in the Triumph I heard that was some good s..t.
Triumph guy
butterthegreat
posted June 06, 2008 03:32 PM
Is this sarcasm?
Yes...there are tons of oil threads.....no one likes to search.
mcmmotorsports
posted June 06, 2008 03:36 PM
Re-read my first sentence in my first post...I searched.
jeff martin
Pro (closed)
jamming
posted June 06, 2008 05:55 PM
+1 Best bang for your buck. Do the research !
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
butterthegreat
posted June 07, 2008 07:21 AM
Probably not that well....IIRC I even started an a VERY similar oil thread almost a year ago....so I know something is there. The reason I don't post much is because I find most of what I need through searches.
posted June 07, 2008 07:43 AM
Motul 3000 10w-40 they make Kawi oil. I used it and then switched to 300v synthetic at 2500.
0.2702579498291 seconds processing time
