BIKELAND > FORUMS > ZX-14.com > Thread: 06 and 07 zx14 frame recall NEW TOPIC NEW POLL POST REPLY
smokinzx14
posted May 29, 2008 06:30 AM
It's true Kawi is recalling some 06 and 07 zx14s ..
Kawasaki ZX14 2006-2007 Motorcycles Recalled
May 24, 2008
Make / Models : Model/Build Years:
KAWASAKI / ZX14 2006-2007
Manufacturer : KAWASAKI MOTORS CORP., U.S.A. Mfr’s Report Date : MAY 12, 2008
NHTSA CAMPAIGN ID Number : 08V222000 PE08021 NHTSA Action Number: PE08021
Component: STRUCTURE
Potential Number Of Units Affected :
Summary: KAWASAKI IS RECALLING CERTAIN MY 2006-2007 ZX14 MOTORCYCLES. THE REAR SUSPENSION CAN COLLAPSE WHEN A CROSSMEMBER SEPARATES FROM THE FRAME.
Consequence: FAILURE OF THE FRAME COULD RESULT IN THE REAR OF THE MOTORCYCLE COLLAPSING CREATING THE POSSIBILITY OF A CRASH RESULTING IN INJURY OR DEATH.
Remedy: DEALERS WILL CHECK THE TORQUE OF THE ENGINE MOUNT ADJUSTING COLLARS AND INSPECT AND POSSIBLY REPLACE THE FRAME IF NECESSARY. THE RECALL IS EXPECTED TO BEGIN DURING MAY 2008. OWNERS MAY CONTACT KAWASAKI AT 1-866-802-9381.
Notes: CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
slates
posted May 29, 2008 07:44 AM
I just called the Kawi 1-866 number listed, and the guy I spoke with has no knowledge of such recall???
Smokin...do you have the source for this info.?
lietoome
posted May 29, 2008 08:27 AM
damnit.
Burnoutzx14
Stretched/Lowered/NOS
posted May 29, 2008 08:51 AM
Hmm, this has me wondering now. Since i'v owned the bike new i have always heard a knock/clunk sound from the rear suspension over bumps. I can feel it on the left foot rest. At first i thought it could be chain slap, but its not. Still did the same thing after i lowered it and stretched it also, nothing has changed. I'v looked all around for anything loose but dont see anything.. Now i wonder if i do bring it in to the dealer, how much shit/hassle they are gonna give me for it being modified..? "Sir its probally your extensions or the nos bottle making the noise, we cant find anything wrong" Blaw blaw
rOck oN!
  Ignore this member    Click here to visit Burnoutzx14's homepage.
butterthegreat
posted May 29, 2008 09:24 AM        Edited By: butterthegreat on 29 May 2008 10:24
Go to safecar.gov and look it up....it's there:
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
posted May 29, 2008 01:38 PM
i read they had 5 complaints, no accidents or injuries, i'll be glad to let them check it for free tho
tater
Shakin off the Haters
posted May 29, 2008 01:53 PM        Edited By: tater on 29 May 2008 14:53
Hey smokin, is kawasaki recallin all of them or just some? From 06-07, And do i have to call someone , even oif mine has not cracked?
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
lietoome
posted May 29, 2008 01:56 PM        Edited By: lietoome on 29 May 2008 14:58
The only information listed on the recall site is whats posted above.
I'm also betting its all 06/07's.
ninjaboy311
posted May 29, 2008 03:20 PM
It's also here....
http://www.usrecallnews.com/2008/05/nhtsa-1138.html
billeason
posted May 29, 2008 03:45 PM
Take the bike to a competent dealer'' Have them look at it,if it's not cracked your fine, The problem is motor install from factory. Its real easy for them to tell. If you have had your motor out you better have it checked'' Burnout zx14 don't sweat it take it in kaw knows its their problem,being stretched has nothing to do with it. If your dealer gives you shit show them the recall and the nhtsa.dot listing. Then go to another dealer with the info. LMK how you make out.... Bill....
bill eason
FasterThanStink
posted May 29, 2008 03:54 PM
So much for the individuals on this site Poo Pooing the frame crack issue! :P
That's what gets you.
ZREXER
posted May 29, 2008 07:01 PM
I figure since my bike is 2 years old now ('06) if it was going to crack it probably would have by now.
I have to give Kawasaki credit for stepping up on this. If they only have 5 cracked frames as someone else mentioned, it's a pretty small number. I wonder how may '14's were built in 06/07? What is the guess in cost to completely strip down a bike and rebuild it on a new frame? Labour cost has to be huge........how many hours would be involved in doing this? It scares me a bit how good the build quality would be considering some of the monkeys that work at some of the shops I have seen. Probably hand your bike back and a bag of 'extra' left over fasteners!
Is the recall 'Evergreen'? I mean if your frame checks out fine now but cracks 2 years from now are you still covered if you reponded to the initial recall?
Questions, questions....
smokinzx14
posted May 29, 2008 07:34 PM        Edited By: smokinzx14 on 29 May 2008 20:34
Well we didn't poo poo the fact that it happened ...We could clearly see the pictures of the cracked frames that were posted ...Some did as myself the poo poo the how and why the frame cracked..
I and a few others saw what the problem or cause of the cracked frames some time back .. Others and myself reported that removing or installing the lower motor mount bolts and spacer would cause this problem ..I think some of these broken frames were cause by the owner or shop that pulled these motors for whatever reason .. ( repairs or hot rodding the motor ) Now we can also see that mother Kawi may have installed a few motors and got the torq spec of the frame spacer and that may have cause a problem in a small number of bikes ....A two year run of these bikes and looks like we have 5 that went bad .. Some may have been Kawi falt and some may have been the owners doing ...We will never know for sure..
Good news were the reports of this that caused the recall ...Now if down the road years from now your frame cracks on you 06 07 zx14 you will get a free frame and repair !!!! Once you go to the dealer for the recall and has passed inspection you will still be covered if down the road if it does crack ... The recall never ends or goes away...
ZREXER
posted May 29, 2008 07:48 PM
Well, that answers one of my questions that the recall is 'Evergreen'.
So as long as you don't die when your frame fails on a high speed corner, they will rebuild you a new bike! So far it it does not seem that anyone has crashed due to a frame failure which is fortunate.
Checked mine closely tonight with my mag light to really light up the area. Looks fine. Have it happened on both the right and left sides of the bike or have the failures always been on the same side?
smokinzx14
posted May 29, 2008 08:09 PM
I have seen it on both sides ..Like you said check your frame before you ride and you should be just fine ... Also if you do get on the recall list make sure you get the recall done .... If the dealer does the recall and the frame cracks after guess what ??? NEW FRAME ... Either way Kawi picks up the tab ...
The only real problem is will the dealer do it right and what about the frame VIN numbers ?? You can't just stamp numbers in the frame and call it a day ...That is against the law for anyone including the dealer ...Only the DMV and give out a new number and that means new title or salvage title ....It's hard to sell a bike that has had the frame replaced, oh you can sell it but for a lot less money ....Better deal would be for Kawi to replace your bike with a new one ...
ninjaboy311
posted May 29, 2008 08:15 PM
Not that's what I'm talking about, I sure could use a fresh motor. Mine runs great, but would be nice to start with a new one. Too bad there isn't a recall that would replace your entire engine with a new one.
blackbullet76
posted May 30, 2008 03:51 AM
Can someone describe in detail or perhaps post a pic of exactly where the crack is supposed to be? Mine's an 07.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Burnoutzx14
posted May 30, 2008 05:14 AM
Thanks Bill... I went to the dealer i bought my bike from and they knew nothing of it, just gave me attitude. I showed them the printed copy of the safer.gov paper but they said they cant do anything untill they get word from Kawi. But i will go back next week and check agian.
Anyhow does anyone know where the cracks are? Or pics of the cracked areas? I'd really like to check mine just for piece of mind for now.. Thanks!
rOck oN!
Sticks_n_Stones
posted May 30, 2008 11:00 AM
Yeah Burnout, I've had the exact same issue, even posted it up here but no one else seems to have that problem. I thought that only the RIGHT side was susceptible to cracking so I only looked there. I just ran out and cleaned/looked at it and didnt see anything, but I'll wait until I put it up on my stand to be sure.
Now fellas, are we talking about the lowest engine mount? with a 1" or so spacer between the frame and engine? There is a couple engine mounts in the area, just want to be sure>
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
BobC
posted May 31, 2008 01:41 AM
I think my 14 is ok, I'm in around that area of the frame quite a bit when I change suspension height and haven't noticed anything.
However, this might be of interest. I sent email to Kawasaki UK a couple of days ago asking for information on this and the silence so far is deafening. They probably can't respond until a corporate decision has been made about European ZZR1400's. I'll post if I do receive a response from them.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
blackbullet76
posted May 31, 2008 03:54 AM
Pics anyone?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
posted May 31, 2008 06:36 AM
We'd like to keep all the information in one topic for the membership. Please do not start multiple frame recall topics.
This thread is closed... follow the link below.
Thanks...
LINK TO OFFICIAL RECALL TOPIC
0.27855110168457 seconds processing time
